Can anyone point me to a BCM module removal link? for T1? I have an ´04 V8 4CAir. have a (J519 control module for network) fault code, 00457 and 00470 (combination comfort databus in single wire).
I have searched and I can´t find any detailed instructions or video for the removal. I have the bottom cover off and I thought the BCM could be removed from the bottom but I don´t see an easy way? Do you have to remove the lower dash? Also, is there any troubleshooting other than the faults? Recently I had water in the harness under the drivers headlight that caused airbag crash sensor, air temp sensor and Hood sensor issues. I dryed it all out, put her back together then she sat for 4 days in a parking garage. It rained yesterday and the front end got wet but not the whole TReg. When I go back last night it started but no headlights, signals, hazards, no Voltage reading on the guage and the mirror control was not working. I went back today and drove her home in daylight. She drove great except for those issues. I checked voltage and alternator was charging at 13.5+. I scanned it and saw these faults and know the BCM controls all these systems. I also rechecked that harness again that had water in is and it was full of water again. I cleaned it all out and dried it but I still have the issues. Is it possible the water in the harness fried the BCM?
Anyway, Id appreciate if yáll could tell me if the dash has to come apart to get to the BCM or if it comes out the bottom with the right technique. Here is my previous issue with the water in the harness.
