not a very difficult trail, but the leaves were pretty.
"ground clearance" is generally measured from the lowest point of the automobile. So assuming r-line has a body kit that hangs lower, that would be the lowest point of the car.Bruh... you're just not getting it.....
That's straight suspension drop.
Here are the numbers, just for you.
Front -10mm, Rear - 16mm
Then you have the "ground effects" that chew up the angles
Yes you're definitely right. And you're right that most ROW markets do indeed indicate a drop with the r-line, but I don't believe that to be accurate in NAR market TouaregDifferent market, so specifications may be different - but in the UK the 2016 specifications show R-Line is 25mm lower than the base SE while the Escape (4XMotion) is 10mm higher than the base SE.
I would have bet money it was you that made this post because I remember being in complete shock that you said you were selling your airstream and then your Touareg. There's only one more person in here famous for camping on the forum and that's @EddieB - and he definitely sold his camper and TouaregMust be mixing me up with someone else. We use this combo about 5 months every year - shoulder seasons in spring and fall. No plans to change that yet. Maybe when I am getting ready to put it in storage for a while you're thinking otherwise.
As I said above generally "ground clearance" is measured from the lowest point of the automobile,which would often be a bumper or body kit.That’s really not much ground clearance… but a lot of traditional solid axle body on frame vehicles are reporting clearance from the lowest point on the diff or suspension when everything actually delicate is much higher.
I’ve found that for your basic southwest desert sandy road, a stock Touareg will go everywhere, but it will be scraping the underbelly a lot more than ideal.
Believe what you want to believe.. ordered replacement rear springs last year through the dealer, the springs for the R-line are a different part.Yes you're definitely right. And you're right that most ROW markets do indeed indicate a drop with the r-line, but I don't believe that to be accurate in NAR market Touareg
