Hope someone can shed some light before I spend what could be several thousand dollars on an air suspension repair. Had the car in for repair of front left upper control arm which had been rattling for a while whenever going over bumps. That was a $800 repair. Within 2 minutes of pick up from dealer, the warning light with up/down arrows in display appears with "fault running gear workshop" warning. It comes on every time at apx. 2 minutes from starting of movement with vehicle. I noticed the clearance in wheel wells on left side of car was less than right side but air suspension was still working through range. Back at the dealer, aside from the fact they seem genuinely confused, they are telling me the following. There are leaks in a seal at top of both front air suspension units. There is a repair kit for it that costs apx. $160 per unit which involves new/better seals. Then they suggested there may be a larger repair required that involves replacement of all struts at $1600 per corner. The repair they perform depends on whether the extended warranty covers it.
Does any of this make sense?
