1 - 11 of 11 Posts
Wrinkledpants
Discussion starter · #1 ·
I wouldn't say it's sputtering, but it sounds like it's under load. If I shift to neutral, the car settles backwards like it was straining to move forward, and the motor runs fine. Shift back into D, and the motor sounds rough - rough enough that I can feel it in the steering wheel and hear the difference over the radio at a normal volume. I'm almost 100% sure I have a stepper motor issue as well (binding at tight turns, brake assist workshop that clears with key-off and then back on). Could these two things be related?
Car is an 06 V8 with 100K miles and the TB was done 10K miles ago. No other indicators that something is wrong. Car shifts and drives fine once under way, and the rough motor smooths out the minute we start moving.
Discussion starter · #7 ·
Weird - that hasn't been my experience. Both my Audi and my Porsche operated perfectly after 200K miles. Keep up on maintenance, and these cars should last longer than we will. In fact, I've never owned a car with less than 90K miles.
100K is way too early for a transmission to start showing it's age in this car. Certainly, some cars from VAG have notoriously unreliable transmissions, but this car doesn't seem to be one of them.
I find it hard to believe that a german engineered car would start running poorly at 100,000 miles. Does not say much for VW, no wonder your a toureg mechanic.
The titles given to user names is based solely on the number of posts and is automatically assigned by the website.
It is no indication whatsoever of a member's skill set so ignore the titles!
Personally I think it is silly and very misleading to new members who do not realise how the names are awarded.
I, for example, am not a "guru"!
This ain't a Audi or a Porsche. VW auto transmissions are known fail items. On all models. Do a search on valve chest.
1 - 11 of 11 Posts
