1 - 8 of 8 Posts
meggsy
2016 MY17 V6 TDI Canyon Gray Metallic with Pano Roof and Air suspension
Discussion starter · #1 ·
Hi Its a pain in the bum that the OEM coding for the tow module disables the electric opening of the tail gate can I change just that if so how -- I only have an OBD Eleven - Vehicle is 2013 7P Thanks guys/gals
You can, after searching the forum I found the coding but I used VCDS..
Sent from my Pixel 4a (5G) using Tapatalk
There is a VCDS modifications thread that lists all the cool mods that can be done.
Meggsy, check this coding from another thread.
And a little more progress,
Most of the coding changes are self explanatory in vcds. In most modules, in one of the bytes there will be a bit to be checked for trailer recognition module.
In my case so far changes were made in,
19, can gateway. Installation list, check 69.
46, central convenience. Byte 12
Engine, byte 5
09, central electrics. Byte 18
10, Park assist. Byte 0 (gives option for trailer hitch not installed. Trailer hitch installed (manually removable) or trailer hitch installed (electrically operable)
3C, lane change. Byte 2
6D, trunk. Byte 4
8B, adaptive Cruise. Byte 0
13, auto distance reg. Byte 0
6C, back up cam. Byte 8
69, trailer. Byte 0. Selected market country Australian. I was getting an ACC and front assist disable message on the dash if the trailer module was left coded as "rest of world"
I'm sure there will be something to change in the Auto trans and ABS. But vcds isn't giving much info in the long coding helper.
1 - 8 of 8 Posts
