Driveshaft center bearing!!
7.8K views 23 replies 11 participants last post by  Spiegelglatt
Hi friends,
I have to replace the center support bearing on the driveshaft of my 2008 V6.
I'm very mechanically inclined and would like to do this myself.
Does anyone have pictures or links to get the CV joint off the old shaft so the new bearing can be installed?
The job seems straight forward except for how the CV joint comes apart and go back together again.
Any help or link to video would be greatly appreciated.
Ed
Thanks Ragman,
Yes I have watched those on the "split" bearing.
I would like to change the bearing with the original style and not the split one. What I'm looking for is how the CV comes off the driveshaft. I understand there is a lock ring behind the CV and wanted more specifics as to how it's on there and how to take it off (CV that is) and put it back on...ie. Lock rings etc. the bearing part isn't a problem, just the CV without loosing or damaging the ball bearings.
thanks
Ed
As above, Search. There are photos and how-to's on here and www.mytreg.com.
Yes.
EPS European Parts Solution sells a rebuilt and balanced complete until for $399 plus a core charge so there will be some shipping expense. I just ordered their split bearing and will have it tomorrow. Guessing overnight on a complete unit would be quite pricey.
They are in Florida.
EPS | European Parts Solution
Since I haven't figured out how to attach more than on photo at a time in the CT app here's the second part of that post.
I removed what was left of the diaphragm. The bearing still spun smoothly and quietly.
I then contacted my local FLAPS (NAPA in my case) and they had some 18mm (OD) Gates 5000psi hydraulic hose that filled the gap tightly and since it was in there scrap pile, it was free!
Using angle grinder fitted with a cutting disk, I cut it into 1 inch sections. The sections were slightly large (outer diameter, and you want this) to fit in without squishing them slightly with a pair pliers. I inserted eight of them across from each other, evenly spacing them out around the bearing, and secured them with zip ties.
They are tightly fit in around the bearing and securely hold it in place.
Reassembled, eyeballing that the shaft and bearing assembly were centered and positioned correctly.
Smooth driving is back and even under hard acceleration there is NO vibration.
W hen you insert the hose pieces like that you should have a continuous row of them with no gaps at all. And please fit all the zip ties the same way for neatness!!
Doesn't everyone? lol
If you want to really add 'class to your home driveshaft fix just alternate colors of pieces of hose! Green and red go well together. Future owners will really appreciate it!
