1 - 5 of 5 Posts
dctreg
Picked up my T-reg yesterday. So far the only problem I've noticed is that the driver's-side window doesn't auto-up. Auto-down works fine and both up and down work fine on the passenger side. Has anybody else experienced this problem?
Mine works fine...
It only works with the ignition on, not just key in the slot. With just the key in the slot, the "auto" up/downs don't work (if i remember correctly).
I'll double check later today for you.
The automatic only works when you turn the car and give electric power ( not turning it on, just the electric)...
It's been my experience that the auto up/down only works when the engine is running. If the key is just in the ignition switch only manual works.
1 - 5 of 5 Posts
