Hello to all,
I have to change again the drive shaft center support bearing.
Can you please share with me your advisor opinion or experience about the JBX support upgrade?
Does it last much longer then OEM/standart part?
No problems with vibrations?
www.jxbperformance.com
Many thanks for your support.
1st gen Cayenne/Touareg Driveshaft Center Support Bearing Carrier Upgrade — JXB Performance
Permanent solution to center support bearing rubber failure on the 1st gen Cayenne/Touareg. Two piece design does not require disassembly of the driveshaft.
Porsche 955/957 Cayenne, VW 7L Touareg Tunnel Brace (95502A0) — JXB Performance
Tunnel Brace for 955/957 Cayenne/7L Tourareg
