1 - 1 of 20 Posts
Thanks for the pdf Laggy, I hope it will prove useful for me
My problem is the opposite :confused:, my rear drivers side door wont unlock :mad:!!
I can hear the lock trying to unlock using the key or the lock on the drivers door, but it wont unlock. It sounds as if it tries to unlock and then immediately locks again, as if the lock is prevented from unlocking fully.:chainsaw:
Will have to try removing door panel with door closed to get at lock, perhaps it is just a small adjustment (maybe a small tap will free it up ](*,)) so that I can then open the door to get to it properly. Hopefully will get to it on the weekend
I will let you know back here how it goes
Does it stay locked from both inside and outside? How old is/are your battery(ies). If they are getting on a bit, try jumping from a fully charged battery to the jump points under the bonnet as it may be a power supply issue. John
1 - 1 of 20 Posts
