Hi all,
I know there are plenty of video tutorial available on youtube showing how to clean EGR on older Touareg... But I couldn't find any info on how to clean it on the 2nd generation (>2011) Touareg. The EGR on the newer touareg seems different... Anyway, i'm thinking of removing the EGR valve out and clean it along with the intake with Liqui Moly Pro-line intake system cleaner diesel. But i'm worry that it is not gonna be a walk in the park, as i thought. Could any one of you whom has did it yourself shed me some lights on this?
For your info, below is a snippet of my scan result from VCDS I did this morning.
Friday,19,August,2016,09:51:12:51960
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 16.8.0.3
Data version: 20160803 DS255
Ross-Tech: Home
VIN: WVGZZZ7PZBD029948 License Plate:
Mileage: 62343km-38738mi Repair Order:
Chassis Type: 7P (7P6)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 22 28 32 34 36 42 46 47
52 53 55 56 5F 62 6C 72
VIN: WVGZZZ7PZBD029948 Mileage: 62343km-38738miles
08-Auto HVAC -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
34-Level Control -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CASA) Labels: 059-907-401-V2.clb
Part No SW: 7P0 907 401 B HW: 7P0 907 401
Component: 3.0TDI EDC17 H17 0006
Revision: 51H17---
Coding: 296A0012232E00000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401B 001006
ROD: EV_ECM30TDI0117P0907311A.rod
VCID: 2E59036E71DDBD3202-807B
1 Fault Found:
4807 - EGR System
P0401 00 [101] - Insufficient Flow
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 62335 km
Date: 2016.08.19
Time: 08:05:06
Engine speed: 1652.00 /min
Normed load value: 42.7 %
Vehicle speed: 69 km/h
Coolant temperature: 71 °C
Intake air temperature: 30 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.240 V
Unlearning counter according OBD: 40
Mean injection quantity: 14.49 mg/stroke
Control Module temperature: 39.3 °C
EGR_governor_deviation: -243.4 mg/stroke
Inj Ctl q Curr: 14.61 mg/stroke
Standardised airflow ratio: 1.1537
Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 162.6 kg/h
Actual charge pressure: 1225 hPa
Readiness: 0 0 0 0 0
Ross-Tech: Home
Revision: 51H17---
1 Fault Found:
4807 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 62335 km
Date: 2016.08.19
Time: 08:05:06
