2016 VR6.
First I don't know why my battery is dead. More on that below. I thought my key battery had died as I had gotten a few warnings to replace the battery. So I went to the CVS by my office and changed it, but the car would still not open. Nothing. I tried to use the emergency key but it would not unlock the door. First question. Does the emergency key still need battery to open the locking mechanism? How do I get a charge on my battery without being able to open the door to open the hood?
My car is stuck in my office building garage so even towing it would be very difficult with the low height restrictions and narrow space. What does someone do to fix a dead battery on a 2016 Touareg when the battery is 100% drained, and it won't even open the door?
As for the battery. I noticed this morning before I even turned the car on that there was a fan on from the engine. I believe it is the radiator fan not the alternator due to how loud it was. I am used to this fan being on sometimes after I shutdown for a few minutes but it did not make sense that it was on before I even turned the car on.
Then happened again when I went to turn the car on after dropping off the kids, the fan was one before I switched the ignition on. But the car was even below operating temp (odd it usually takes 2-mins to warm and stay warm) after I turned the car one. A good 40-degrees below.
When I parked in the garage the fan was off, but I am guessing that something is going on that is triggering the fan to turn on and it drained the battery. Ultimately, I need to get the car to the shop, and my problem right now is how do you charge a completely locked and dead battery 2016 VR6?
Anyone know if the cooling fan is part of the 100k/10year powertrain?
