Im in the process of converting my T3 rear coil suspension to Cayenne air springs. My goal is to keep the rear level when towing our trailer, and avoiding the weight distribution hitch conundrum. I just got it powered up today and excited to share what I have working so far.
I'm using:
- 2 height sensors from a Land Rover Discovery 2 to measure ride height in the rear L&R. These sensors output analog 0-5v, and are under $20/each.
- VW Touareg solenoid bank $100
- Siemens Logo PLC
Currently testing with a compressed air tank and only the drivers side air spring, still waiting for more parts to arrive (3 weeks). I also have a constant current power supply setup to adjust the shock dampening.
I have an automatic mode working which sets a minimum pressure in each air spring, and inflates/deflates to keep the height within a +/- 0.5" window when the load changes. I can make the tolerance tighter, but then it pumps / vents each time I enter/exit the car. Automatic mode is indicated by "white" LCD illumination.
I also have a manual mode where I can jog each bag (or the pair) up/down. All the set points, calibration constants, and alarm limits can be changed on the PLC using the built in keypad and LCD (no laptop laptop required). I was able to install everything without removing any interior panels. Manual mode is indicated by "Orange" LCD illumination.
If a fault occurs, LCD illumination is Red. All manual functions continue to work if a fault is detected. Automatic mode switches off when a fault occurs. Toggling Auto mode Off-On will clear the fault and resume Auto mode. A remote touchscreen can be connected via ethernet. There is also a webpage server I have not yet tried out for a smartphone interface. My goal is to forget the PLC is there and have it just work.
Gauging if there is any interest out there if I made this into a DIY kit.
I'm using:
- Siemens Logo PLC
