1 - 7 of 7 Posts
RayC2
Discussion starter · #1 ·
Hi Chaps
I've collected all the bits for fitting paddles and have worked out the wiring to gearbox etc but have seen a number of different codings for the gearbox with paddles can someone please let me know the best code to use, my car is a 2007 R5 TDI
thanks
Ray
Hi Chaps
thanks
Ray
add 8192 to your current code
Discussion starter · #4 ·
so if i add 8192 to this
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 CL HW: 09D 927 750 CL
Component: AL 750 6A 1022
Revision: 00H61000 Serial number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 7AFDCC2D3695B3C86F1
No fault code found.
to get 12468 the world is a paddly place :D
sorry to ask what maybe obvious to you but i dont want to cause a monumental cock up the car the wife now wont let me use even though it is for me to do tyre testing on!
Coding: 0004456
0012648 is exactly right. I recoded to that when I installed my paddle shifters a year ago, and everything works as it should.
Rayc2,
You'd better get someone to confirm because after my paddle shifter install this is what I had to change and works perfectly in my '08 V6TDI:
Before...............
Part No SW: 09D 927 750 FT HW: 09D 927 750 FT
Component: AL 750 6A 1168
Revision: 00H75000 Serial number:
Coding: 0004456
VCID: 850B015FB5B1
After ....................
Coding: 0012392
VCID: 850B015FB5B1
Note also that other information is also different from what you posted.
Thanks to Aussie forum member Stewart (Hedditch) for giving me the above code.
Tony
Good day
After I replaced my 2008 V6 Touareg MFD Cluster with colored one (I Installed used one shipped from German to Saudi Arabia) everything worked fine :D without reprograming the colored cluster even the gearbox was shifting smoothly but after I take my car to VW dealer to connect it and remove faults, they removed all codes and reprogram it again with new codes :x after this process the gear box start jerking and jumping while shifting especially on speed No. 2 Dead Horse
My question: Is there any relation between the cluster and entered codes with gearbox shifts? If yes please advise me what to do or tell me what the best code is to be used in order to have smooth gearbox shifts.
Appreciating your support in advanced. :wave:
1 - 7 of 7 Posts
