meggsy
2016 MY17 V6 TDI Canyon Gray Metallic with Pano Roof and Air suspension
Discussion starter · #1 ·
HI I have lots of space at the back of the Treg when the trailer is attached - the OEM coding disables the boot door from being electrically opened. I find it a right PIA... has anyone recoded the OEM setup to allow electrical opening of the boot
Thanks in advance -- Ian
Interestingly mine is setup to open with the trailer connected. that’s how it was delivered to me after the tow bar was fitted.
To be clear if I operate the handle on the hatch it opens up fully.
I rarely ever use the remote key fob or internal switch in the drivers door for the hatch so I don’t know if it still works via those options when the trailer is attached
[edit]. And I do not have “easy open” kick to open option.
Yes, it can be coded to have it either way, I changed mine to what you need, it's a simple change in the trailer module.
I can look up the notes if you have trouble finding it in vcds
tow control module coding parameters would be awesome thanks @Singh
I will need it soon.
Reactions: Singh
Discussion starter · #5 ·
Thanks -- my VCDS-HEX seems not to talk to my carso I use ODBeleven so any info would be great. thanks.
