Greetings all. My 2004 V6 has an exciting and interesting new bug. The "check brake lights" warning light comes (with the accompanying beep) on frequently under certain conditions, and I wonder if anyone has experienced a similar problem or knows the likely root. The condidtions under which it happens are as follows: 1) The brake lights are fine and working normally; my bulbs have been replaced 2) it happens almost always when the Egg is at a stop or very close to arriving at one, after the car has been driven for about five minutes 3) it always happens when my foot is ON the brake pedal 4) it usually continues to happen two or 10 times on each trip -- under the above conditions.
When it happens multiple times, it can be rather maddening!:anger:
I have also experienced a "check headlight" warning. At the time, the driver-side xenon low-beam bulb appeared to be out. After a short drive, I rechecked the headlights, and the bulb was in fact working fine. There have been no headlight warnings since.
My thought is that these two problems are related and are a symptom of a malfunction in the warning system component(s) themselves, and that this should be covered by warranty.
If you have experienced this, please respond and let me know what your resolution was with your dealer -- and how you accomplished it. I have 53,500 miles on my Egg and am now under the RealDriver Platinum extended warranty. Now that the factory warranty is expired, I need to be able to point to a specific diagnosis in order to have the work covered.
Thanks!
Thanks!
