I went to get my discs machined today, and they told me I need to replace the pads immediately. I'd really appreciate any advice!
No vibration. Yes brake is very fine but they asked me replaceVisually looks like a lot of brake pad left on that and seems ok.
Does the car brake ok?
Does it have warped discs? (eg you feel vibrations?
Doesn't look like there's too many groves in the rotor either.
QFT. It's 99% of the time the INNER pad that locks up and wears to high hell on most vehicles, which you're not seeing w/out pulling the wheel off in many cases.VW does not allow the machining of brake rotors on these cars, if they machined your rotors they destroyed them, and they owe you a refund of the work, plus a brand new set of rotors for free. I'd ask them to pay someone else to do this work, as you can't trust them.
You need to get a digital caliper and measure the thickness of the rotors, and see if they are now below the allowed thickness spec, and if so replace the rotors ASAP.
It's extremely dangerous to machine the brake rotors, because if they're below the wear limit, the pistons can pop out of the brake caliper, and cause the wheel to lock up suddenly and/or catastrophic loss of braking ability.
However, for future reference, it is not safe to assume that brake pads wear evenly on any vehicle. A photo of just one pad doesn't tell you anything, you need to look at all of the pads, inner and outer.
