Its a long shot but is it possible to do the fronts my self for under 250 usd I know the front rotors need to be replaced as well
Could you advise me why you would need to change the speed sensors??Nope...! Front rotors and pads would cost you more than $250, even if you do it yourself and use cheap aftermarket parts.- Do not recommend this -. There are better aftermarket parts (i.e. Hawke) available but would be more than your allotted budget. Don't forget to change the wheel speed sensors too!
Brakes would work, but i wouldnt run different pads front and rear or at least ensure they were the same friction rating.What are Textar pads like? Is there any issue mixing pads between front and back? Pagid front and Textar rear on Zimmerman's?
