1 - 11 of 11 Posts
ltatkinson
Discussion starter · #1 ·
What are you guys using? How strong are the mounting spots from the factory? The tow hook from the factory seems pretty weak and not much to hook to.
Tim
Discussion starter · #4 ·
I have seen the Dakar in other thread's and from how they look in the pix it looks like I could have the guys here at the shop make them. Would you or have you used the stock one to pull out a stuck Touareg? If so does anyone know how much the dealer sells them for?
Tim
The stock hooks can be found at the usual places -
VW Touareg Bumper Tow Hook : Touareg Accessories & Parts : TregCentral
and probably at 1stvwparts.com, so on. mid-$20's price.
I have two VW Tow hooks, as I wouldnt want to do recovery on just one. I couldnt tell you the rating or durability of the stock hooks - certainly they should work for ordinary situations. Dragging a 6000 lb Touareg up a steep rock ledge on its rockers - not ordinary - your call.
(edit - I have not personally been winched out - *yet*... I have come close. )
A spare tow eye is about $20 if I remember correctly. I've never needed to use my tow eye for a pull out, but I do have a receiver mount D-ring shackle that I use for the rear. That I have used to pull and to be pulled.
Discussion starter · #7 ·
I have one for the reciever also but no hitch on the T2. For what they want for one I dont see one in the near future. That is why I am looking for other options.
Tim
I have pulled and been pulled by the stock tow eye numerous times with no ill effects at all. Think about it: With all the sue crazy people here VW wouldn't use this method unless they knew it would work. Imagine the liability if it broke/snapped during a recovery.
Those tow hooks are surprisingly tough... despite what we may think. I agree with Nefarious though... VW wouldn't put them there as a tease.
That was the reason I posted the link to the picture where we used them on mine to change that flat. They were the factory hooks and mounts. They car went no where or were any of us worried about it.
I see the beefier tow hooks more as an image thing - to put on shackles and so on - though if used frequently I would wonder I little (fatigue). In any case, its recommended to weight something over the tow strap in case the hook or strap gives way to avoid the whipping action.
I do see getting a second tow hook as useful, so that both sides of the vehicle can be pulled evenly.
1 - 11 of 11 Posts
