21 - 40 of 40 Posts
Discussion starter · #22 ·
So... Connecting another BT device didn't seem to make any difference. Pulled the module and reconnected. Actually pretty easy, although the cables didn't really want to extend and required a little careful rocking, but once the unit unseated fully, there was more than enough room to work with the connectors. Calls seem to be OK now. Probably just a coincidence and will be inaudible again tomorrow, but for the moment, perhaps this worked? Which would be kind of amazing, considering it cost nothing but a few minutes of my time.
Markoffate,
Are your BT calls still clear to the receiving person after pulling and re-setting the module?
I recently purchased a 2016 Touareg LUX TDI, and the bluetooth sound reception for whoever is listening to the person in the car is the worst I've ever heard. I have tried finding the mic sensitivity in VCDS and have had no luck for this model year. Same goes for finding the Green Screen. I have tried every way I can find through searches, and my car either doesn't have those modules, or they don't connect, and the button pushing to get to the green screen doesn't do it, either.
I did pull off the cover to the Homelink panel to access the microphones, though, and stuffed the empty space between them and the roof with foam from jewelry boxes. This made a remarkable improvement. It's still not crystal clear, but it no longer has the choppy, intermittent sound that it had before. I may try to find some better foam or sound deadener and re-do it. Here is a picture of what it looks like with the cover off. There are tabs on all four sides of the cover, but the largest ones are on top, so I recommend prying up the cover from the bottom first. I managed to do it without damage.
I would still like to play with the mic sensitivity, so if anyone knows how to do that via VCDS on a 2016 model I would appreciate it
Sorry for the delay, I was out of town. I have the RNS850 (2016 LUX)
I'll attempt to post the autoscan here.
Monday,03,June,2024,19:05:51:35517
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64)
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVGEP9BP6GD005010 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 52 53 55 56
5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BP6GD005010 Mileage: 120988km-75178miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF82755A21130E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 23038 444 00000
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 306F72D16BA9EE16F3-8064
VINID: 9E65D58094A0197500005001002095B32D
1 Fault Found:
31035 - NOx Sensor 2 Bank 1
P22A0 00 [01100000] - Signal too Small
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 120787 km
Date: 2024.05.21
Time: 13:47:17
Engine RPM: 1799.00 /min
Normed load value: 69.8 %
Vehicle speed: 109 km/h
Coolant temperature: 89 °C
Intake air temperature: 21 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 14.600 V
Unlearning counter according OBD: 29
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 130 3374
CVN: E0C27B10
Coding: 010500000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 408F2211DB097E9603-8014
No fault code found.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 41675440304263 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F58DAF4C89492D2F6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4C970621E741AAF6EF-8018
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GK HW: 4H0 907 064 GK
Component: BCM2 2.0 H37 0572
Revision: 00002001
Coding: 0D860016000000000000
VCID: 78FF8AF1CB59F6567B-802C
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3215000120752006
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CN HW: 7P6 907 040 CN
Component: Klima 2 Zonen H23 1507
Coding: B686200A80
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 020BE8199585AC8655-8056
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001153086901
Coding: 26000096963C5D010020480000005D4C431C6608A2014265000000008040110000000000000000
VCID: 6ADBA0B985F554C6FD-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150726 033 0021
Serial number: 90243400150812065611
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20633057
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000002408150186
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0203E049
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0155896186
Coding: 952F00
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231522303200
Coding: 310D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44872E01CF1162B627-8010
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Serial number: 00000000000000
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C7756E1B7E11A765F-8068
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 F HW: 7P0 959 655 F
Component: VW10Airbag02B H10 0044
Revision: -------- Serial number: 003S8000VT3G Dataset Number: 7P6003V____ 1733
Coding: 000000000000000000000000000000003242
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Seat occupied recognition:
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R155210QHEW
Crash sensor for side airbag: driver side:
Serial number: 3575LRB40633J2B23OVF
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB40593C8NAA0NF
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB40613GN32IOPH
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB405V3GN3298SP
Crash sensor for front airbag: driver side:
Serial number: 3557BRB40533GUUMAGB4
Crash sensor for front airbag: front passenger side:
Serial number: 3567BRB404T3FSU04GK8
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OHO0000Z
Coding: 000CDD
VCID: 3D715BE5A4FB137E68-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0092457 TRW 20150601
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 D HW: 7P6 920 983 D
Component: Kombi H13 0515
Revision: 13240302 Serial number: 658220815592023
Coding: 835733026F08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526_VW52.rod
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001958690 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB5F40651D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 43852D1DCA1F658E1E-8016
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 32196A45215701427761
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000158777943
Coding: C0581B0015004001000001010101202020202121202020
VCID: 356143C59CCBCB3EA0-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0377729427 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW52.rod
VCID: 3F8D21EDA6F7016E7A-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0378277357
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000164554706
Coding: 011D17205E00453005080001
VCID: 7AFB90F9F555E4460D-802E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0377478423
Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 191155513
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P0 959 591 D HW: 6R0 959 591 D
Component: J245 PS30.408 H03 0004
Serial number: 0000FST000GYQDH00000
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 E HW: 8V3 959 591 A
Component: J394 PS30.408 H03 0004
Serial number: 0000FST000GVBSE00000
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65030039
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000164097108
Coding: 011D17205E00453005080000
VCID: 489F3A31FB3946D6CB-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1573000158 Dataset Number: A001
Coding: 01040200
ASAM Dataset: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
VCID: 366344C989CDC026A9-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0017
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156H00F8303774
Coding: 020007020000000001
VCID: 24478E81275142B607-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 K HW: 7P6 035 664 A
Component: H-BN-NA H41 0933
Revision: -------- Serial number: 606H.0F7502525
Coding: 010200050040E9EF79022B0E00000003F00001030000000000
VCID: 408F2211D3097E9603-8014
Subsystem 1 - Part No: 7P6 060 884 B
Component: NAR 2015 1202
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H56 0046
Serial number: VWZ8Z9RGG003AW
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 6208
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000163779574
Coding: 011817200000253005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000023515 Dataset Number: 7P6096V____ 0029
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 45813305C42B5BBE30-8010
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H20 0160
Revision: 7C001003 Serial number: 0376767687 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 377D49CD8EC7392EB2-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H08000 Serial number: 525 PA8JA71816
Coding: 0130001
VCID: 377D49CD46C7392EB2-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 212501159 Dataset Number: 7p0771v____ 0012
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000164398557
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 39794FF5B8D32F5E44-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007066260_3132
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A7B50F9BDD524464D-806E
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H33 0035
Serial number: 005000011908157
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
End-------------------------(Elapsed Time: 07:13)--------------------------
@Dieseldog -- Pro tip: Bracket your VCDS log text in a CODE block to preserve white-spacing/indents.
So, no fault code from the RNS850 main unit (Address 5F). You wrote above that you can't start the Green Engineering Menu (GEM). You should check with VCDS whether Address 5F Adapation Channel 06 value is set to '1', which enables "Development test mode". When "Development test mode" is enabled, start the GEM by pressing and holding [SETUP]+[CAR] (that is, press and hold [SETUP] a half second before pressing [CAR]).
And MU Software version 0933 is already the latest for your U.S. main unit. --g
I will try that, thanks.
I finally got into the green screen. I suspect that on my prior attempts I was not pressing the Setup button slightly before the Car button. I played with the mic db settings, and zero works the best for me. I also pried up the Homelink cover again and replaced the jewelry box foam with some materials I had leftover from sound proofing my truck several years back. Using small enough pieces to fit up there (roughly 2"x5"), I inserted some MLV (Mass Loaded Vinyl) and some higher density sound proofing foam up between the roof and the microphones. The easiest way to get the cover off is to insert a thin putty knife or similar tool into the center of the side of the panel, pushing in on the release tab, and then working your way around the bottom, up the other side, and then the top will pop out. Between the sound proofing and changing the mic db setting to zero, the listener's reception quality is greatly improved. It sounds about like talking to someone who is on speaker phone. You can hear some road noise, as expected, but it is quite clear and no more choppy, clipped sound.
There are a lot of settings in the green screen, but I haven't really found a list of which ones people have played with. Does anyone have that?
That's because you're more likely to break things -- for example, MMI menus -- than add or change the functionaility of car systems. Individual control module long coding and adaptations are generally where you would make changes to affect the behavior of those control modules (for example, "celebration" (AKA needle sweep) in 17-Instruments). --g
Check out the thread in the link below.
Unfortunately it's not stated exactly where this is except it's in the green menu.
Just be sure to write down how you get to that menu and any and all original values you change just in case.
Link >>>> https://www.clubtouareg.com/threads/vagcom-microphone-gain.78768/
Be careful -- this looks like a (very) early Green Engineering Menu definition that no one should be using now with US_K0711 (and later) and EU_K0841 (and later) software versions. The current GEM definition for mic "sensitivity" should look like the image in post #11. --g
I honestly did not look/see what firmware was being run within that thread.
I notice that the pic in post #11 shows the mic sensitivity @ -6db. In the thread I included they say that +6db works better.
By way of your picture in post #11 the sensitivity can be adjusted on newer firmware. So does the +6db setting actually sound better than the -6db setting?
After installing sound deadening materials, I drove the car at 60mph and talked with my wife, trying all three settings, -6, 0, +6. She said that 0 sounded the best, so I left it there. I might try switching between 0 and +6 with her driving and me at home on the phone so that I can listen to it. I suspect which setting works best may be dependent upon the ambient noise levels near the mic (noise deadening material), but I can say for sure that what I've done is a huge improvement to what I had.
Seems the best repair/fix for BT sound quality issues is the installation of the sound deadening material.
Definitely a better option for some rather than messing with the green menu.
Update: While driving 75mph and talking with my daughter, I switched back and forth between 0 and +6 on the bluetooth mic, and she said +6 sounds better. I suspect that the db setting is dependent upon whether or not you have soundproofing material around the microphones.
Discussion starter · #38 ·
Markoffate,
Nope. Back to terrible quality. In retrospect, not sure that pulling the module really did anything - maybe was just the imagination of the people on the other end of my test calls... Thank you for this suggestion. I'll give it a try. Seems like a pretty easy fix. Are you still getting decent reception?
My wife is driving it right now, 75mph and into a headwind. I just talked to her and I could hear road noise and her voice could have been a bit louder, but there is no more of the garbly, clipped audio that it used to have. I would say it sounds about normal for a car bluetooth traveling at that speed. A significant improvement over what it was. I wish that she knew how to change between 0 and +6 on the green screen so I could hear for myself the difference, but that's not going to happen!
Does anyone know which direction makes the mic more sensitive vs less sensitive? -6 or +6?
I believe -6 is less sensitive and +6 is more sensitive.
21 - 40 of 40 Posts
