any a/t tires for 19 inch wheels?
13K views 17 replies 9 participants last post by  Joshua
Ive given up on finding 17's so now im wondering, are there ANY all terrain tires out there that would fit the factory 19's on my touareg 2?
There are not to many tire sizes for 19Ëť wheels at all. Better keep looking for 17Ëť, much more tire sizes and many more AT tires.
x2
You could look out for 18 inchers too - again there is more choice of tires
Imho, don't do it...a low side wall and offroading are a no-no, especially for your control arm bushings, suspension, rims and.....butt....this tire would come in a 275/45/r19 size and it's a size that wouldn't allow lower psi's. There's no meaning in riding on these tires....not good on road or off road...very, very special tire...
They're not low profile per say but what's the meaning of sacrificing a 3/4 of an inch in sidewall height over the 265/60/r18s? Lower sidewalls are better in terms of on road handling...as I see it you're looking for some off road action with this tire thread...you're going to suffer more with this size...not to mention all the suspension components that you need to consider protecting...higher side walls offer extra cushioning and are more adjustable in different off road conditions...ofc you might have something else in mind and all I'm talking here is just conventional thinking...
I was merely adding an option, in response to the OP's request for info.
I agree with the 18" option (check out my sig and my first post on this thread), but that was not the question.
The question was re 19" AT tyres. (tires for the US guys :) )
He did not mention what the intended application is. If it is 'mild' off-road excursions, 255/55/19's would do just fine, regardless of brand.
As a matter of interest, I did the Sani Pass between South Africa and Lesotho in my V10 with 285/45/19 Michelin low profiles, without any problems. Knowing your vehicle and your tyres (especially their limitations) will take you a long way.
I would however not do 'serious' off-road work with those.
Sani Pass - Wikipedia, the free encyclopedia
Op, do you have a tdi or the v6 listed in your profile? If only the v6, you have the option of going a little larger in tire size due to added clearance from not having the intercooler in the wheel well.
Ditto from Wisconsin
You guys should take those statements to the classifieds.
You might be able to find someone in your area looking to cross-grade.
Offroad interests or maybe someone with some steering shake.
