I’m wanting to install an Anderson plug on my 2013 7P, wondering if anyone has wiring diagram choosing best route from battery to rear of car for cable.
Hi Steve_LPeter,
There are fused points available next to the battery under the passenger seat.
Cabling is easier if you run into under the carpet from that point to the door sills/B pillar base, then follow the cabling route back, over the rear (left) wheel arch, and then into the cargo area from the rear left area.
This is the way we went with my R Line.
I'll send you something in a PM which may also help![]()
I gather the running current is 90 amps @ 13.8 volts that you are referring to -- so what is the starting current ? I gather that you are running about 3AWG/B&S ( 25 -30 mm sq) size cable for a 3% Volt Drop which means that your device will actually be dragging 93+ amps from your system... since the alternator is only rated at 180 Amps @ 25 Deg C and considering all the other circuits that are drawing power you are probably close to your alternators max rating. So to prevent any spikes or faults being recorded for low voltage I would suggest that it may be prudent to remember to switch off as much as possible Aircon + Aircon system fansI am in the process of running leads for a 120A Anderson plug
I did try to turn the pic around and save it the correct way but it reverted when I posted it --- but its really is an upside down world just now -- so I dont feel out of place !!!!😎😎O M F G .... you guy REALLY are upside down
