Hi All, I have read through a number of posts regarding Air Suspension issues but have not found the exact issue.
car 2015 7P v8
Issues. ‘Stop Running Gear’ warning
I only get this intermittently when I go into comfort mode. Ride height doesn’t seem to change.
another issue I have seen is: the front does not go as high (as it used to) in off road mode and doesn’t change when choosing special off-road.
normal, load etc work no issue.
I issue seems to have come after tyres were changed, tech did mention he out the car in Jack mode.
Once car is switched off the error goes away and may not return for a couple of weeks and only in comfort mode.
my fiend did pull the issue fault codes but not sure they are showing much as the coder was not fully aligned to VW, but have attached
anything I can check physical or would you recommend a recalibrate?
car 2015 7P v8
