Air suspension reset
1.4K views 8 replies 6 participants last post by  adidas
Hi
Has anyone reset there air suspension with a suggested step by step guide to reset the heights using VCDS in module 34. Car is currently sitting on the bump stops.
Regards
Garry
Hi Ian
The car is currently in for a service so cant answer the DTC scan question. They are having trouble doing the height.
Currently suspension pumps up ok but on normal goes back onto the bump stops.
Did you have any warnings or issues with the A/S that led up to the current problem of not keeping pressure in the struts?
Tony_B
Seems like you have quite the air leak. Vehicle needs to be scanned, leaks repaired, then having base settings programmed by a competent mechanic or the dealer. If your mechanic needs to YouTube the procedure, move on.
Reactions: seafarer28
That's for the 7L. 7P is a different procedure.
Reactions: lachoradkov
Module 34:
1. Code: 210673
2. Adaptations: Left front level ctrl sys sensor: adapt. value (zero pos) -> put your measurement from center wheel.
Right front level ctrl sys sensor: adapt. value (zero pos) -> put your measurement from center wheel.
Left rear level ctrl sys sensor: adapt. value (zero pos) -> put your measurement from center wheel.
Right rear level ctrl sys sensor: adapt. value (zero pos) -> put your measurement from center wheel.
3. Adaptations: Complete Height Calibration -> YES
4. Basic Settings: Level Control System -> Select Normal from drop menu then Start -> Finished Correctly
5. Basic Settings: End Basic Setting -> Start -> Finished correctly
