Hi there again
I have an issue with my air suspension. A week ago the air suspension was functioning normally. Now it takes too long to fill and the compressor kicks in while the car is raising up from sport to comfort mode and I don't notice the car raising or lowering.
The compressor runs for a short while when I start it up then shuts off; and I assume the tank is full. Then I raise and lower it to test the ride height and it is speedy at first then it's super slow on the second test. The second time is when the compressor kicks in and the ride height adjustment takes forever. About a minute to fill up to comfort from sport vs 5 seconds last week.
When entering the car to turn the engine on (because I need an inspection done and the car sits for a week before I drive it around the block to keep everything going) I heard some form of noise. I don't know if it is an air strut popping. I Inspected the air struts on all 4 sides and I don't see anything that would indicate that the air struts have blown or else the car would probably sit to the side where the blowout occurred.
I suspect it might be an electrical fault as I've had no issues with the air suspension for the 2 years I've owned the car.
Anyone else have similar issues? This would be grateful when I take the car into the stealer to get it fixed.
