Air Suspension Hose
3K views 6 replies 4 participants last post by  noobytoogy
Several questions:
All Touaregs have an air compresser that can be used to pump up tires?
Where can I find the hose for this?
It's not under my rear left seat. Should it just be there in plain sight or do I need to look harder?
Not all Tregs have air suspension. The non air suspended Tregs actually have a small portable compressor in the spare tire well. As for your situation if you hose is not under the rear seat anywhere or in the with the spare tire, then you more then likely are without one and no idea how much that will cost your. Earlier years it was located under the rear seat bottoms, I believe. My 10 just had it in with the spare tire in it's own pouch. You can thank the previous owner for taking it and not returning it before trading the car. That is just as bad as the people that remove the cargo cover and don't put it back in the car before they get rid of it.
Do air suspended Tregs have both the air suspension and the compressor in the spare tire well? As you can see, I have both.
If so, steel suspended Tregs must have a different compressor than the one in the photo?
My God, that's not an air tank!
You've just discovered Saddam Hussein's weapon of mass destruction.
TAKE COVER!!
kaboom
Thats the tank you see in the picture, the compressor is under the drivers seat(air sus touaregs). non air touaregs have a portable compressor which sits in place of the tank
Under the drivers seat in your part of the world. Would be the passenger seat here in NA. ;)
