Yes. Easy enough. Just answer some questions and add some numbers together.
Can you make sure the ball joint can hold another 100k km? That’s about what the lifetime of the bushings on this car is. Both sides. There is a test procedure you can do to verify if the ball joints are ok but it won’t tell you how long they will last.
Do you want to use oe or aftermarket bushings? Compare both oe bushings from vw and aftermarket prices. The hydraulic bushing alone from vw is around 90 $ if I remember well. The Lemforder ones are not cheap. Gazaflash will give you his prices.
Next question: how do you remove replace the bushings? Can you do it yourself or are you going to pay for it? How much?
Can you make sure you or the guy doing it will be doing it right and not find out once you start driving that it was not done right? It’s not rocket science but Gazaflash will give you his feedback about how he did it and what the total cost was. When you’re done and assuming everything went smooth you have to balance the Treg. And you’re good to go. Almost all the bolts/nuts/washers have to be renewed. These you need to buy from vw. Not expensive. Mark the eccentric washers and their bolts and copy that to the new washers bolts to make the balancing job easier. And preload the suspension before tightening things to the correct torque specs. If you don’t know what preloading means just ask. If you don’t have the vw torque specs just ask.
Put the cost of this job down to paper.
Now 10.000 km down the ball joints go out .Or not. If they go you’re good for a new arm, new bolts and whistles and new balancing.
I paid 250€ for two new TRW arms from amazon. Got the bolts from vw. That’s 125€ for one arm. With bushings only from vw I was in for more than the price of the arm. One arm from vw costs an arm anyway
I will give you vw prices later. With Lemforder I was not far away from the price of a whole TRW arm. I don’t want to go back there for the ball joint in 100.000 km if I can pay 20€ more and be done done with it unless I need to.
That’s how I calculated the real costs. No guessing or living in ‘fear’ that I might need to redo it again because I spared 20/30$ and will probably pay for a whole arm later. Maybe the ball joints are eternal but on mine they were tired. I even looked for custom arms with removable ball joints.
And it can be a tough job. You don’t want to do it again soon. A friend burnt the cv joint when he used his torch to remove a stuck rusted bolt.
Let me know if you need instructions. While you’re there do the end links too. They’re not that expensive. I used TRW end links. Next on the list: TRW upper arms bought from amazon germany.
