1 - 5 of 14 Posts
Bol3ethem
Discussion starter · #1 ·
Hi all,
I have a 08 V6 FSI
I went off-roading the other day, and once I was back on road I noticed the (check brake pads sign) and also another problem!
I tried overtaking a car, and once the RPM reaches 4k rpm there is a huge drop in the car and no power response. So I released the gas pedal and applied it back "gently". I've noticed that the car runs PERFECT while it changes gears under 4k rpm!
I tried putting it on (N) and revving the engine, the same exact thing happened. Right on reaching 4k, the tachometer just instantly drops to 2k then 3k while my foot is steady on the pedal! and then the epc light turns ON. After that the engine is ALWAYS on 1500 rpm!
Any help from you guys is appreciated!
Othman
Discussion starter · #3 ·
Exactly as you described!
Am heading over to friend in a couple of days to scan it.
However, was it an expensive fix?
Discussion starter · #7 ·
Just got the touareg scanned.
Apparently no misfiring issue!
yet found 8 faults only in engine, hope you guys can figure it out considering am a touareg noob.
Address 01: Engine
8 Faults Found:
012408 - Throttle Control
P3078 - 002 - Airflow at Idle too Low
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 82660 km
Time Indication: 0
Freeze Frame:
RPM: 676 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 87.0∞C
Temperature: 30.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 153006 km
Time Indication: 0
Freeze Frame:
RPM: 100 /min
Load: 95.6 %
Speed: 0.0 km/h
Temperature: 85.0∞C
Temperature: 45.0∞C
Voltage: 5.969 V
000801 - Engine Speed Sensor ( G28 )
P0321 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 88
Reset counter: 255
Mileage: 153513 km
Time Indication: 0
Freeze Frame:
RPM: 1430 /min
Load: 31.4 %
Speed: 9.0 km/h
Temperature: 72.0∞C
Temperature: 38.0∞C
Voltage: 14.224 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 153657 km
Time Indication: 0
Freeze Frame:
RPM: 3071 /min
Load: 87.0 %
Speed: 38.0 km/h
Temperature: 76.0∞C
Temperature: 20.0∞C
Voltage: 13.970 V
000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0050 - 004 - Malfunction / Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 153657 km
Time Indication: 0
Freeze Frame:
RPM: 3071 /min
Load: 87.0 %
Speed: 38.0 km/h
Temperature: 76.0∞C
Temperature: 20.0∞C
Voltage: 13.970 V
000802 - Engine Speed Sensor ( G28 )
P0322 - 008 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 153658 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 94.1 %
Speed: 38.0 km/h
Temperature: 76.0∞C
Temperature: 20.0∞C
Voltage: 14.224 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 153675 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 43.9 %
Speed: 38.0 km/h
Temperature: 76.0∞C
Temperature: 20.0∞C
Voltage: 14.224 V
000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0056 - 004 - Malfunction / Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 153675 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 43.9 %
Speed: 38.0 km/h
Temperature: 76.0∞C
Temperature: 20.0∞C
Voltage: 14.224 V
Thanks in advance
Discussion starter · #9 ·
Might sound silly, but mine (09) had a few of the same codes (esp. the "implausible" one) as a result of a dying battery, also with the rough running/low power symptoms kicking up after a bit of modest off road driving...
Yeah I replaced the battery 10 days ago!
But did you had the engine "bogging down" all of sudden when you accelerate hard?
Discussion starter · #14 ·
V6 doesn't have much of an engine cover, so hit a decent depth of water at a (relatively) high speed = lots n' lots of water under the hood...
I did exactly THAT when i went off-loading the other day, So you have a valid point :clapclap:
1 - 5 of 14 Posts
