2012 VW Touareg 3.0TDI engine overheating, no hot air, irregular coolant loss problem
37K views 38 replies 16 participants last post by  Gusty
Hi everyone, i'm new in this forum.
I have a big problem with my car which no one in my country (Estonia) cant help me, so im hoping, that someone from here can.
Symptoms: at highway speeds car will overheat slightly (110C or so) and temp gauge moves up and down. At the same time there is no hot air coming from vents. Sometimes i can regulate engine temp with lower gears, at high revs, it will drop to 90 C. But sometimes it will go to 120C for a second and blows some coolant out and then drops to 90 C again (this happens in the matter of seconds). Then is everything ok and warm air comes from vents.
Sometimes engine temp is fine, but still no hot air from vents. Today morning (-13C outside) i started my car for warming up and after 30 min engine temp was 90 C, but cabin was cold and after i started driving hot air came.
Strange thing is, that sometimes the car works just fine about 1 week with no problems and sometimes it one day works and other day not.
I have already changed thermostat and some other coolant regulator valve (059121737am). VCDS wont show anything.
I have to add coolant sometimes over 60 miles sometimes over 600 miles. Dealer said, that there is no leaks and it boils out sometimes.
I hope i made myself clear enough.
Tauno
Im betting its air in the line... goota bleed the system properly otherwise you dont get proper heat dissipation.
Take the radiator cap off and run engine to vent it all out. Radiator reservoir will drop so keep filling it.
Squeeze all lines gently in order to push them air pockets out. Please dont stick ur hand it places it shouldnt go though. YOU LOOSE ANYTHING ITS ON YOU NOT ME.
Hope this helps
Heater core issue possibly? If its cracked or there is a clog it will leak out coolant and you wont get any heat in the cabin. Also helps to cool the engine slightly so if you have a slight overheat condition it could be a contributing factor.
How many drive cycles (drive, warm up to operating temp, stop, let it cool down) have you done since the repair?
X2 on there being an air pocket somewhere. It can take a few drive cycles to work itself out. As the air is working itself out, it would be normal to have to add coolant to the pressure reserve tank in order to replace the "air" that was lost.
Xeno555-Waht do you mean?
FSJ Guy-countless cycles.
Coolant loss is because it boils out from coolant reservoir. Sometimes i have to add coolant after 1000km, sometimes overnight. Yesterday it boiled out some coolant when i left the engine running and visited shop for 10min. Engine temp was 90C.
If worried about a possible blockage, you could flush the system.
The tests would then start by putting pressure on the empty cooling system. You then wait several hours to test for pressure loss.
Then you pull a vacuum and wait several hours to see if you lose vacuum.
Fix the above if needed.
If that passes without needing repairs, I wold change out thermostat and water pump.
PS: You can not work on a modern engine without something like this. Anyone who thinks they can will end up in a world of frustration. Engineers assume that you use such a tool to replace coolant so they don't make any allowances for modern engines to burp or release air pockets anymore.
https://www.ecstuning.com/News/Univ...999_2000_2001_2002_2003_2004_2005_2006_2007_2008_2009_2010_2011_2012_2013_2014/
The fact that cool air comes out of your vents means 1 of three things: 1) Air in your cooling system 2) partial blockage in the cooling system or 3) the valve that permits coolant to flow through your heater core is failing/failed. Given that you also have intermittent overheating issues it is 1 or 2. More than likely, I really think it is air in your cooling system. You are aware that I just had a similar issue with my 2012 3.6 Touareg and I am almost certain it was a failed thermostat followed by an air bubble in the system due to the thermostat replacement. I recommend pulling the lower radiator hose and the oil cooler hose to drain the radiator and engine block and then use a tool like the one linked below to evacuate the cooling system and let it suck in the coolant. I am not confident these Touareg's can self bleed the entire system. Also make sure you have your key on with heat set to MAX and the fan on to circulate cabin air when you evacuate and refill the system.
One thing I did do that may have helped bleed the air (WHICH I DO NOT RECOMMEND ANYONE DOING) was to get to operating temperature and then (WITH GLOVES AND FACE PROTECTION) unscrew the overflow cap to let the system rapidly bleed off some pressure. There will be a rush of coolant into the overflow tank (especially if there is air in the system) and will probably overflow. Screw the lid back on when it starts to overflow and let the system cool then re-top the coolant to the Max level. Also squeezing the upper and lower radiator hoses can help move coolant/air around.
Coolant evacuation and fill tool
can't post links since I don't have enough posts... Seach for a schwaben Coolant Refill/Air Purge Tool. I got mine from ECS tuning.
Hi put the funnel in the coolant bottle and run the engine till it gets warm and keep topping up the water until all the bubbles have finished coming to the top of the funnel, also make sure the heater is on full so the coolant can circulate. If this does not fix your problem check to see if the radiator is evenly hot (top and bottom) otherwise you may have a blockage also double chech the correct thermostat is installed.
