2012 TDI blown head gasket or wors
4.3K views 59 replies 8 participants last post by  SaVAGeSoot
While driving this weekend the coolant light came on, soon after the engine began overheating and lost power. No heat, smells like burnt coolant. Popped the hood and found the hose popped off the radiator. I waited a bit before turning it back on and drove to the nearest auto parts store and refilled the reservoir with coolant. Turned it on and the temp started to go down so I began driving hoping to make it home. Made it a few miles, never had full power, pulled off to the side and it turned off on me before I could turn it off. Checked the reservoir and no coolant had circulated out but there was plenty of pressure built up.
The shop I towed it to doesn’t seem to want to touch it, he said any repair will likely outweigh the cost of the car. I called another shop and they think it’s likely the head gasket.
Could this be as simple as the head gasket? Seems much more sudden than other touaregs with gasket issues I’ve heard of. And what are the chances the heads are warped due to me driving it several miles after the problem began?
@LarryBeaut ignore the dice comment.
It's going to be hard for anyone to diagnose whether the head gasket is blown or if the heads have warped over the net.
What most can tell you is that if you lost coolant to that degree, you'll need to be sure all hoses are correctly replaced then have the coolant system vacuum filled with the proper coolant and tested for any leaks.
You'll also need to do an scan the vehicles modules for any stored codes, save the auto-scan, then reset the codes and see after that if the vehicle starts/drives/gets up to temp properly.
You need to bleed the air out of the coolant system with the proper procedure, or air expansion will keep pushing the coolant out and keep it from circulating, making it overheat and pressurize almost exactly like a blown head gasket, even if it's not blown. Hopefully that is your entire issue... but driving it without coolant was a big mistake, you shouldn't have done that.
There are two tests you can easily perform at home after proper bleeding and filling to confirm head gasket failure: a bubble test (look it up), and a combustion gas leak test. The latter is done with test strips or an indicator chemical you can purchase cheaply online.
Any mechanic that says "it's not worth fixing" without doing any diagnostic work is completely incompetent... don't even consider taking any vehicle to them ever.
It only takes a short time at 260 to ruin a lot of things.. if you pulled over everytime it was past halfway on the display you have a chance. The display is kinda fake.. it's straight up for running parameters of 200 to 230. That's why it suddenly races to the right as a stop now or else. Vw are known to have horrible bleed procedures to coolant.. the pump cavitates and turns to an air bubble makers. We would take mk4 vw and audi to a ramp of 40degrees to get the bubbles out of the heater core.. good luck..
No you wouldn't- you will get massive hot spots that aren't anywhere near where the sensor is located. The sensor is actually on a coolant pipe outside of the engine, so isn't measuring anything at all if you have no coolant in the engine.
The coolant gauge isn't nearly as important as the coolant level sensor. As long as you have coolant in the engine, it is safely at or below the boiling point of the coolant. Once the coolant is low there is no telling how hot some parts of the engine are getting. I would never except in an emergency drive with the low coolant light on for more than the time it takes to safely pull off the road.
In my Touareg I typically drive with my OBDLink sending continuous coolant temp data to my phone, and my phone has an audible alarm which sounds if it gets above a reasonable threshold (I think 110C) so I could pull over and let it cool before way before it were to boil over. The OBD data isn't 'fake' like the gauge. I've only ever pulled over to let it cool once- climbing up the dirt road to the Cerro Gordo ghost town at 8500 feet altitude.
Omfg stop. There are zero auto parts stores that carry g13 coolant. Flush your coolant system and put the proper g13 in before you cause more damage.
#52 ·
Is that all you got, the basic vw purity test of factory or the highway? I ran a large vw club for about five years.. basically.. eat me.. I mad bank doing dash kits back in the day for dealers on new cars..
Thank you for the suggestion of the 140 sticky pads to clear my rotors.. who knew you could step out of that spotlight inshow you are staring in.. great advice
