Hello,
On my 2007 vw touareg 3.6, the battery was replaced last year by the dealership. Then months later we had the dreaded timing chain issue whych led to a new timing chain and rebuilt engine earlier this year.
Recently, the battery started dying. It was fully recharged and reconditioned and then would die a few days later. We took it to the dealership who swapped out the batteries, supoosedly didnt find any unusual error codes, and did a drain test checking the fuses and it cleared the test without issue, but the battery is still showing a slow drain.
Does anyone have any thoughts on what may be causing the drain?
The dealership wants to tear apart the dash and test that area but wants 600.00 mlre just to try to possibly find what they havent be able to find with multiple days of testing. I’n hoping someone might know what could be causing this if when the fuse test passes.
Thank you!
Thank you!
