1 - 7 of 7 Posts
colinh
Hi All,
My name is Colin and I am new to this Forum.
I have a 2006 VW Touareg that has a newer Valve body that does not have the transmission fluid pressure sensors G193 and G194.
The transmission operates perfectly, smooth as the day it was new. However, the engine check light is on and the transmission is logging the following error code.
If I clear the code it turns back on again, like clockwork within 10 minutes of driving.
It almost looks like the code is incorrect in the TCM for this valve body, expecting to see the pressure signal and not.
Appreciate any feedback on what may cause this problem
Many Thanks,
Colin
> 2 Faults Found:
> 17225 - Transmission Fluid Pressure Sensor/Switch 1
> P0841 - 010 - Implausible Signal - Intermittent - MIL ON
> 17230 - Transmission Fluid Pressure Sensor/Switch 2
> P0846 - 010 - Implausible Signal - Intermittent - MIL ON
> Best Regards,
> Colin.
1 - 7 of 7 Posts
