So I ran and cleared all the faults with VCDS. I am going to try and fix these issues one at a time. Any help here would be appreciated. Ignore the headlight issue I already know about it and I am still refusing to spend $600 for a new light fixture when I just did it last year and it leaked and shorted it out.
Monday,13,August,2018,17:01:18:65392
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WVGHH77L94D067078 License Plate: 777777
Mileage: 271410km-168646mi Repair Order: 8888888
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGHH77L94D067078 Mileage: 271410km-168646miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 BG HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMÂŞ5676
Revision: 5KO3 Serial number: VWZ3Z0D7162508
Coding: 0060575
Shop #: WSC 31414 000 00000
VCID: 56F68FA65418AAB77BB-5160
1 Fault Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 1449 /min
Torque: 55.3 Nm
Speed: 86.9 km/h
Load: 9.4 %
Voltage: 13.83 V
Bin. Bits: 00001000
Temperature: 93.6°C
Readiness: 1 1 0 0 0
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
VCID: 2F381A420B02BB7FD8D-5160
Component: ELV XXXX
3 Faults Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
01176 - Key
008 - Implausible Signal - Intermittent
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 L
Component: 2703
Coding: 0111839
Shop #: WSC 09217 444 54273
VCID: 45D458EAB9BE112F021-5160
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
00907 - Intervention load Management
000 - -
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - Intermittent
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 36362F26F4588AB79BB-5160
2 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
012 - Electrical Fault in Circuit
00003 - Control Module
014 - Defective - Intermittent
Part No: 7L0 959 933 E
Component: 2N HSG 0201
Coding: 0000085
Shop #: WSC 09217 444 84771
VCID: 3E263706DC6842F743B-4B1E
Subsystem 1 - Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
2 Faults Found:
00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
007 - Short to Ground
00930 - Locking Module for Central Locking; Rear Left (F222)
End----------(Elapsed Time: 08:09, VBatt start/end: 13.7V/13.7V)-----------
Thanks for any help in advance.
www.Ross-Tech.com
Coding: 0060575
1 Fault Found:
Freeze Frame:
RPM: 1449 /min
Torque: 55.3 Nm
Speed: 86.9 km/h
Load: 9.4 %
Voltage: 13.83 V
Bin. Bits: 00001000
Temperature: 93.6°C
Coding: 0131304
Component: ELV XXXX
3 Faults Found:
011 - Open Circuit
01176 - Key
011 - Open Circuit
Component: 2703
Coding: 0111839
3 Faults Found:
000 - -
Coding: 0015521
2 Faults Found:
Coding: 0000085
2 Faults Found:
