1 brake light stays on
20K views 10 replies 8 participants last post by  c4ar
Just noticed a little while ago while my wife was pulling away that the drivers side brake light looks be lit all the time. The other side and the center brake light comes on fine when she's on the brakes.
I searched but didn't find anything relevant, anyone have an idea what I could check?
The brake pedal switch is a common failure on VWs. It went out all the time in my Mk4 Jetta. The USUAL symptoms are no brake lights at all and no cruise control since its tied in. But, who knows nowadays. Easy to replace. Just make sure you dont push the plunger in until u have it mounted in the vehicle. Then it will set itself.....;)
Did you ever get your bizarre electrical problem resolved?
Could it be related to any work done?
