Is it possible to turn it off in vag? i know it needs breaks its annoying seeing it on the dash. Would also like to kill the TPMS as well. thanks in advance
Thanks, the rotors are warped any way lolSimple trick .... the sensor is simply a wire loop which gets broken by the contact with the disc ( rotor), make up a dummy plug with a simple loop. Will effectively negate your wear sensors so you will now be able to destroy your rotors completely...but!!, Hey, who cares? You must have plenty of money....LOL
Stuart..
Stuart..
