My plan is to drive out to Buffalo next week and pick up a 2006 19-ft Airstream bambi, and tow it back to Vermont. It weighs about 3750 lbs empty. It will be my first time towing anything.
I've read a LOT of the amazing threads here; learning fast, but still confused.
First, everyone has advised me to get a light-weight WB hitch (like 600 lb) and install it. My Treg is a 2013 TDI Lux. I don't think it has an air suspension, but I don't know, and it's not in the manual. Dealer didn't know either. Does it even matter? Of course, the manual says not to use a WB hitch.
Second, the Airstream is 8-ft. wide. The treg is 6.35 feet wide. Will the Treg mirrors be enough? Or should I get bigger ones?
Third. The VW dealer/salesman assured me the factory-installed 7-pin wiring outlet on the back of the Treg (next to the hitch) is already set up with a brake controller (done at the factory). But everything I read here says that is not true -- that I have to buy a brake controller and install it, or have it installed. Anyone know if the dealer might be right?
Any idea what tools I should bring for this trip.
Any advice would be hugely appreciated. Thanks.
