Just had my 7P's Rear Left Wheel Speed Sensor fail.
They certainly make for an interesting array of instant dash errors for a good "pre-research freak-out" (ESC/ABS failure, Ride Height failure, Parking Brake failure, Bend Lighting failure, Workshop warning ... )
So my question is there a preferred replacement brand to go for ? Is Bosch ok ?
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 41265439693330 Dataset Number: 7P0012v____ 0001
Coding: 5B6B13C34B246F5ADAF8C894D2D8F670F701
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC6BC3C4648489A232-8018
1 Fault Found:
74243 - Rear Left Wheel Speed Sensor
C101C 07 [01001000] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 166
Mileage: 136924 km
Date: 2025.04.23
Time: 14:42:30
Standard Freeze Frame Dynamic: 00 43 09 67 00 00 00 00 01 00 03 00 43
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 166
Mileage: 136924 km
Date: 2025.04.23
Time: 14:42:30
