2013 Touareg TDI LUX
Tuned and deleted, comes with stock tune and exhaust. Obviously will not pass emissions as it sits, but do have the full exhaust and tune to return it to stock form. Also have a stage 2 tune w/emissions.
Paint is shot, previous owner left a wrap on for 7 years. Car currently is plasti-dipped and looks fine from 20ft. People actually like the way it looks... but it's ugly up close.
I am very cautious after my HPFP failure. The 2 micron filter is awesome and will separate water as well. I run Hotshot Secret at every fill up to keep things lubed.
Known issues:
$11,000 OBO. If you are looking for one like this, here it is. Please ask any questions, I can talk at length about this car. Needing a third row so this has to go. It's been a good ride for us.
Can help arrange shipping.
- 300hp, 500tq Tunezilla tune.
- Full 3" Rawtek exhaust (no longer available in the USA).
- 3" Eurowise lift. Sits on 33" tires w/ decent tread.
- 18" Cayenne rims
- x2 new intercoolers
- 3.7 ratio gears (front rebuilt at time of engine replacement, see below). This was to accommodate the 33" tires. Car hauls great, fast, pulls hard.
- 2 micron fuel filter post factory filter
- Many other upgrades/downgrades if you like it stock!
- Engine replaced in 2022 after HPFP failure with super low mile Q7 CNRB engine including turbo. Now only has 51k miles on it. This was the lowest mile engine I could find and is very clean, no leaks. Cost me north of $6k to purchase, and is likely one of the lowest mile CNRB engines on the road. Since replacement car has about 20k miles on it and runs great, zero problems, starts in cold just fine.
- Religious Amsoil oil changes. I don't mess around with maintenance.
- All fluids replaced at time of engine swap. Including brake fluid and transmission!
- Tow package w/controller.
- T1 rear springs.
Known issues:
- Steering wheel heat no longer works.
- Phone BT doesn't work, I have an aftermarket module hooked up for BT.
