21 - 31 of 31 Posts
Discussion starter · #22 ·
It holds propshaft in place,if you go under you can try to shake propshaft,it should be thight.I am sorry for bad english,i cannot explain better but it is possible that propshaft makes vibrations when accelerate
Thanks for the reply Mark. Correct me if I’m wrong but shouldn’t the new prop shaft have some play because of the rubber around the center bearing?
UPDATE:
After about 250KM, the vibration is way less now.
This is after the automatic transmission flushing, I did change 13L of ATF.
I am thinking that the converter has a problem, and that won't last long before it will start to "shake" again.
It was only 30000km since last flushing.
test torque converter like Alex did in the final pages of big bad mud tyres. Try and mount a gutter and certain revs and see if normal
If the tailshaft was a cheap knock off (Ebay?) then that is almost certainly the problem. If it was a genuine VW part then I have no helpful suggestions, sorry.
If the driveshaft was rebuilt it may not have been put back together properly and the phasing is incorrect.
The orientation of the joints should be perfectly aligned so that the velocity changes as they flex during rotation cancels each other. If the splines are off then they cannot match correctly.
An extreme example is when someone modified a truck to jack it up and they aim the rear end up to reduce the angle of the U joint instead of keeping the same angle as the output shaft of the transmission. The result is a phase mismatch and torsional vibration in the extreme. Sometimes you can actually see the surge at lower speeds each time the driveshaft rotates.
Didn't find that page in that thread.
Can you explain?
My sincere apologies i must have been re-living an SMS from Alex as i remember him showing a torque test or sorts when his problem arose
mounting a small obstacle around 15-20cm high head on or straight on. Gentle on the accelerator monitoring RPM's until you get the the value such that once the front tyres have climbed the obstacle you know at what RPM's the vehicle climbed over. Now compare to another vehicle same as yours
I did this yesterday, and compared to another Touareg R5. They where suprisingly identical rpm match, considering not same tire specs.
This test does not test the "lock up" function in the converter, witch is the main cause of vibration under load..
Altough it seems like my injectors are bad. Very much difference in injected quantity, hope this is the injectors, and not some other underlaying fault making the injectors struggeling. And guiding me in the wrong way. plan is to take an compression test before injectors swap.
21 - 31 of 31 Posts
