21 - 40 of 45 Posts
I have to say, installing floor mats is NOT mechanical…. :)
When I bought my New Beetle I also got a set of the thick rubber floor mats. The guy at the service department "installed" them and said that since he did it (at no charge) and it showed on the invoice then they were covered under warranty.
Not sure if that was really true because nothing has ever happened to them for me to take the mats in for service.
Discussion starter · #22 ·
I'm NEVER going to hear the end of this floormat install, am I? :p
In my defence, it's not like I went in for the single purpose of having them installed. They were installed with a bunch of other service items.
Discussion starter · #23 ·
WooHoo!
VCDS and T91 remote came in last night!
So the first thing I did last night go out and scan the car.
<CRY>
I seem to be having a few issues.
Wednesday,30,July,2014,17:49:23:48105
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: ******D053599 License Plate: ******
Mileage: 157640km-97952mi Repair Order: 30.07.14.INIT.SCAN
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: ******D053599 Mileage: 157640km/97952miles
Address 01: Engine Labels: None
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMÂŞ2813
Revision: 5KO3 Serial number: VWZ3Z0C7145246
Coding: 0060575
Shop #: WSC 66565 257 00032
VCID: 2959E3948342CB56EC9-515C
1 Fault Found:
18315 - Engine Databus
P1907 - 000 - ECU<->ECU Communications Fault
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 0.0 Nm
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 BB
Component: AL 600 6Q 0467
Coding: 0004153
Shop #: WSC 31414 000 00000
VCID: 6FEDCD8C7D26E56672D-515C
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent - MIL ON
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0022785
VCID: 3A7B2CD876E470CE953-515C
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
VCID: 2F6D0D8CBDA6A56632D-515C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
7 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
00457 - Control Module for Network (J519)
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: F7FD75EC85762DA62AD-5140
No fault code found.
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 35613FE45FFA9FB6781-515C
1 Fault Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 L
Component: 2703
Coding: 0111839
VCID: 45814F240F1A0F36E81-515C
8 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
006 - Short to Plus - Intermittent
01498 - Bulb for Parking Lamps; Right (M3)
01336 - Data Bus for Comfort System
01517 - Control Module for Trailer/Towing Sensor (J345)
014 - Defective
00907 - Intervention load Management
000 - -
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - Intermittent
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
02196 - Fuse for Control Module for Power Supply to Vehicle Battery (S287)
014 - Defective
Address 11: Engine II Labels: None
Component: V10 5,0L EDCG000AGSÂŞ2813
Coding: 0060575
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0C Airbag 8.4E+ H10 0952
Coding: 0012355
VCID: 2541EFA4EF5AEF36C81-5140
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 41895B341B322316D49-515C
1 Fault Found:
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 880 S
Component: KOMBIINSTRUMENT RB4 2921
Coding: 0023331
VCID: 479D452C35161D261AD-5140
3 Faults Found:
00464 - Control Module with Display for Radio and Navigation (J503)
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 7L6 815 071 B
Component: Standheizung E1MAC 0235
Coding: 0000000
VCID: 31690BF4AB92B396249-515C
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0EF4EF0E0187A9EEB7-5140
4 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1600
VCID: 0407922044A0F63EBFF-5140
Address 22: AWD Labels: None
Part No: 0AD 927 755 AB
Component: TRANSFERCASE 0094
VCID: 7BF5E9DC395E89C6CE5-515C
1 Fault Found:
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
VCID: E6C328A8D2DCA42E81B-515C
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 366338E842FC94AE71B-515C
Address 36: Seat Mem. Drvr Labels: None
VCID: F7FD75EC85762DA62AD-515C
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000003
VCID: E7DD25ACD5D6BD26BAD-515C
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2N HSG 0201
Coding: 0000085
Shop #: WSC 93036 999 53462
VCID: 3E7320C86ACC5CEEA9B-4B1A
Subsystem 1 - Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
Address 65: Tire Pressure Labels: 7L6-907-273.lbl
Part No: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0210390
Shop #: WSC 93036 999 58819
VCID: F5E17FE49F7A5FB6381-5140
2 Faults Found:
01507 - Initialization Not Successful
000 - - - Intermittent - MIL ON
01521 - Sensor for Tire Pressure
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 377D35EC45F66DA66AD-515C
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 E HW: 7L0 907 383 E
Component: ANHAENGERELEKTRONIK 8254
Coding: 0000002
1 Fault Found:
Freeze Frame:
Count: 0
Count: 0
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 G
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009268.03
VCID: 3B7529DC79DE49C68E5-515C
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 B HW: 3D0 035 617 B
Component: Telematik NAR1 0104
Coding: 0076510
Shop #: WSC 93008 999 59325
VCID: 1F4DFD4CCD0635E682D-5140
2 Faults Found:
01304 - Radio
004 - No Signal/Communication - MIL ON
00003 - Control Module
014 - Defective - Intermittent
End ---------------------------------------------------------------------
Some errors like TPMS I've already started to correct.
I ordered up new ones from eBay;
TPMS OE Replacement Tire Sensor Ferrari Porsche Volkswagen Touareg BY EMS 5 | eBay
Other errors like...
... and ...
014 - Defective
... scare me.
What should my next step be?
Go over every fuse and see if I can find the blown one and replace?
Maybe I'll do that tonight.
Arggg, Now I'm loosing sleep. Lol....
Discussion starter · #25 ·
KGL-4201 came in today.
H7 LED Fog lights as well.
I did manage to install the LED fog lights myself, and man they look good.
They do throw the check lights error code though.
Either an inline resistor or a vagcom to remove the warning? I'll keep searching for the solution.
Speaking of vagcom, this afternoon I did the seatbelt chime delete, what you guys call the six gun salute, and changed over the trans mission to 4202 ROW.
Later this evening I started the KGL install. Loads of fun. There was a JVC aftermarket radio installed. What a butchers job I found in there.
There is another story to the new radio, but I can't talk about it until I make successful contact with a member here first. But she's a doozy of a story.
Also, I'm thinking of changing my tune from Malone to Custom Spooling.
Although the Malone tune added 50hp, it only added 10lb-ft.
Maybe I'm already used to it, but it still doesn't feel like enough.
Lol, maybe I'd to used to the Rzr 1000 and the sleds, but I want this car to feel like them.
The Custom Spooling tune says it adds another 40lb-ft over top of Malone's tune.
Any of you guys ever run both tunes?
Which one gives more umph?
</RAMBLING>
Resistors required.
</RAMBLING>
Have you spoken about your issue with Malone tuning.
I believe to get the best tune for your vehicle you need to do some VCDS logging as per the attachment.
You should be able then to get a specific tune for your car or even their stage 2 tune.
Regards
Drag
Discussion starter · #28 ·
Resistors required.
Duly noted.
Searching eBay now.
Thanks!
Regards
Drag
No I haven't.
And as I read some more I think that your probably right.
Thanks for taking the time to provide that link.
I'm going to do that logging and then contact Mark and ask him what else he can do for me.
I think I'd like to get the most that I can out of this new toy.
Thanks again.
Discussion starter · #29 ·
Never mind the toys - I'll say it again - YOU need to check the correct oil was/is being used. VW dealers can get it wrong on the V10 which is why I made the point in the first place.
Based on the courtesy oil change reminder sticker on the windshield from the previous owner it is time for my first oil change.
And thus began the search on CT for what kind of oil to use.
Wow!
I've learned more in the last couple of days about oil than I ever wanted or needed to know.
I don't think I'm going to send out the oil for sampling, but here is what I did decide to order.
- Pela Pro 14 for topside oil changes.
- Amsoil AFL5L-EA x4; (No DPF to worry about)
European Car Formula 5W-40 Synthetic Motor Oil
Mid-SAPS European Oil for European Gasoline and Diesel Engines
What a great resource CT is for the new guys.
Thanks again Nooby for insisting on oil before toys. Good thinking, even if I didn't want to listen at first. Lol
Bump because I like this thread.
Mark can add more torque for you if that's what you want. I suspect that he isn't adding a lot of torque because of the potential for driveline damage if you get a little too happy with the happy pedal.
Don't sweat it. People pay others to shovel snow for them and that isn't very technical either. If you want to pay someone to do a job for you and you have the means to do, all the more power to you. And you are helping to keep unemployment low.
Discussion starter · #32 ·
UPDATE:
The winter is over.
The snow is almost melted. Only 6 inches or so left in the bush.
The car was pulled out of winter storage a few days ago.
It's time to get back to modding the v10!
Over the winter I had a hard time getting a response from Mr. Malone.
And when I did, he confirmed that this was as good as his tunes get.
He wasn't going to do anything more for me.
So after a little bit of research last night, it looks like I'll be upgrading to a Unitronic S1+ tune.
On Monday, I'll call and book an appnt for install.
The dealer is about an 4 hour drive from me.
In summary, the Malone tune is better than OEM, but not as good as you can get.
Meh, live and learn.
Thank-you for understanding!!!
Discussion starter · #33 ·
The Dectane LED taillights arrived over the winter.
I installed them yesterday afternoon.
I think they look good.
Install was a breeze.
And I received the correct controllers.
Couldn't be happier.
Next up I think I'll order myself the Paser Unico dual plus hybrid canbus resistive Steering Wheel Controller w/the VW wiring harness.
SW Commands Interface - For Aftermarket Radio - Unico Dual Plus - Products - Paser Srl
I think it's time to get the SWC and the reverse input working on the Android HU.
As an aside, I'm getting old and forgetful.
When I put the car away for the winter, I removed the LTE 4G wireless internet from the glove box.
I wanted to put it in a 'safe-place' so I wouldn't loose it.
Do you think that I can find it now????
NO!!!!!
Bah. Another $250 to go buy another one.
And now since installing an Android HU in my wife's VW GSW last week, she wants the internet in her car too.
I'm off to the local Rogers store on Monday.
Discussion starter · #34 ·
Update:
I think I'm finally liking the Malone Tune.
I think it was me.
I was driving it like I would my modified gas 5.3L v8.
Drop a gear and rev the **** out of it and get frustrated with the results.
I wasn't driving the v10 like a diesel.
Since this spring, I've discovered that driving between 2000 and 3000rpm gives the best acceleration.
Revving much past 3k does almost nothing for me.
Driving around town locked in 4th gear gives me some of the excitement that I was looking for.
Similarly, When following someone on the Hwy doing 100 and I want to pass, I lock it in 6th gear and ride the tourque curve, smiling all the way.
Not that I've ever tried it, but they say that locked in 6th using this method can bring you from 100 to 180-200 and back down to 100 in less than a minute.
All I know is that I am happier than ever with the v10.
Discussion starter · #35 ·
My wife dragged me out to Midland to go look at a 40' boat today.
On my way there I could feel a new vibration and some knocking in the center console.
In addition there was a whining noise.
Uh oh. The dreaded center driveline bearing.
I did manage to get home ok.
But it's now parked in the driveway until I get some replacement parts.
Last year I bought a new Vertex EPS replacement rubber mount and the rubber vibration disk from a forum member just in case I would need it.
However I think the bearing is also on it's way out.
Because I am not mechanically inclined at all, I think my choices are a reman drive shaft or a new OEM shaft from the dealer.
I sent an email to these guys asking how much shipping is to my place.
vw touareg/porcshe cayenne drive shaft. | transmission, drive train | Gatineau | Kijiji
We'll see what happens.
If you buy a recon shaft make sure the supplier knows it is for a V10 - that car's shaft is slightly shorter.
Discussion starter · #37 ·
Good to know.
Thanks!
Sooo instead of buying from a random French(Quebec) store from Kijiji, is there a forum preferred vendor to buy these drive shafts from?
No. To be honest there are plenty of workshops perfectly capable of replacing a drive shaft bearing for you. This is a big business sector for trucks, coaches, off-roaders, quarry vehicles, all sorts of stuff, so Google and ask around.
Discussion starter · #39 ·
UPDATE:
So after checking with a few guys around town, it turns out that small random Quebec shop is CVTech.
They do all kinds of work. Good work.
Most guys send their sled jugs up there for nickelsil'ing.
But the point is they are reputable.
My dad and I spent 6 hours to take the drive shaft out.
Packed it up and shipped it out.
It was back in two days with a new center bearing and hanger.
It even had a red seal on it.
Only took 3 hours to put it back in.
Total costs? $440CDN.
That was the good news.
Took it for a drive to Spanish, On to take a boat ride.
(just bought a 40' yacht)
Turns out the car still growls like a bad bearing.
Hmmm, what else could it be?
It sounds like it's coming from the front drivers side.
Wheel bearing?
The sound doesn't vary when driving from side to side, but it must be.
Dropped off the v10 to the local vw dealership.
They confirmed a bad wheel bearing and after $630CDN I got the car back.
Again I take the car to Spanish for a boat ride this weekend.
Again the car still sounds like it has a bad bearing in the front.
The loud annoying growl is gone, but between 80 and 100 there is definitely a pulsing whine in there.
So a quick search here reveals that it must be a front differential.
But I'm at a loss.
What component is it?
And the local dealership just told me the car is fine.
$1100 bucks into it and it still whines.
Not complaining too loudly though. That was still maintenance that needed to be done.
Just wish it would end. Lol
Maybe I'll start shopping for a new diff.
Hopefully it all gets resolved soon, I only have two months of driving it for this season before it goes back into winter storage.
Might sound pretty obvious but we have a lot of cars come into the workshop complaining of suspected wheel bearing problems (reported by customers) that turn out to be the tyres worn weird that cause the noise.
swap the wheels around and see if the noise moves......
21 - 40 of 45 Posts
