101 - 119 of 119 Posts
Discussion starter · #102 ·
your treg looks good! doing some modifications on my own also, but still missing some essential parts for lifting, winshing etc :)
how wide is your light bar?
where did you get your roof basket?
thanks!
The light bar is 42 inches wide and the roof basket is from etrailer.com its a Rola that we welded custom tabs on to mount to the factory roof rails.
Hello everyone, Im now on my second Touareg some of you may remember my 04 v8... http://www.clubtouareg.com/forums/f66/off-road-trip-with-the-new-tires-pics-inside-70645.html Now I have a 2009 TDi with steel suspension. I ordered a lift form Alex, Im sure all of you are familiar with his work, and it arrived very quickly. The quality is great and everything fit right together as it should. Also he was quick to answer any questions I had about fitting the lift. His Touareg is much of the inspiration for mine. I would like to try and fit some 285/70R17 BFGoodrich KM2s or Goodyear MTR Kevlars. If I they dont fit properly then ill go with the 275/65s So far The lift is on and I am working on the roof rack for it. I thought I would post some pictures for those of you who may be interested in Alex's lift kit.. Ill be posting pictures of my progress and if anyone has any questions Id be happy to help. http://s191.photobucket.com/user/Di.../user/Dillonk09/media/036E6B27-CF3B-4073-9D5C-5ACA61A32BBE_zpsb3tdlfq4.jpg.html The front going together... http://s191.photobucket.com/user/Di.../user/Dillonk09/media/5692229C-F0FB-4E33-9E40-776A88F5C57F_zps4ct1rikm.jpg.html http://s191.photobucket.com/user/Di.../user/Dillonk09/media/8B9A2DC8-B55E-43F3-A1A3-CAB38B1AB1EE_zpsbjmmu5hp.jpg.html http://s191.photobucket.com/user/Di.../user/Dillonk09/media/AE32B550-BAC8-4730-BB20-118638490BE7_zpslonzuonf.jpg.html Unfortunately I got excited towards the end and this is the only picture I have of putting the rear together... You can see here how much this lowers the strut assembly. http://s191.photobucket.com/user/Di.../user/Dillonk09/media/192DC83B-5E80-4ADE-92AF-1D1A3DDCFE7E_zpsjy18alee.jpg.html Before and after.. http://s191.photobucket.com/user/Di.../user/Dillonk09/media/5D7F27F5-7468-447C-9C4B-66BF67D7A105_zpsjllkgvpy.jpg.html http://s191.photobucket.com/user/Di.../user/Dillonk09/media/1FAED89C-7C15-4E4D-B3CD-CA89C0FF9C7D_zpsy3ffxbfp.jpg.html http://s191.photobucket.com/user/Di.../user/Dillonk09/media/673129A8-951E-42F3-A9E2-153551318C79_zpsf4gkgpyu.jpg.html http://s191.photobucket.com/user/Di.../user/Dillonk09/media/7FA1F069-1812-4E05-B8CA-C67D5B583730_zpsw89kt55d.jpg.html Im impressed with the ride quality. No real noticeable difference over stock if anything the lift made it feel more solid and sitting up a little higher makes for a nice feeling as well. Thanks for looking! Dillon :wave:
helleo, i ma new in the forum and i would like to lift my 2009 touareg tdi to put bigger tyres to do off-road as well as road ! Need helps . What do i need ? Thanks
Hello Alex. Do you still make the spacers. I need a set ASAP. Doing Fraser at the end of the month. Cheers
He probably doesn't visit CT very often now since moving on from his Touareg, still makes the spacers AFAIK so your best bet is to send him a PM.
TonyB
View attachment 40698 Well I got my wheels spacers. They are inch and a half. Now I just need to track down some 17" wheels. I've been looking at tires. My local tire dealer is going to order 285 70 17 kevlars for me and we are going to test fit them. If it doesn't work out we will go ahead with the 275 65s
Dillon,
Where did you get your wheel spacers from? Also, were they needed with the lift and tires, or did you add them for aesthetics?
Dillon, very nice thread indeed !
I was also recently thinking of installing the winch permanently, but have finally decided to have the front/rear hitch mounted Warn ZEON 12 (12000lbs) and the first reason for that was the possiblity to have it installed either side for winching either way and second was it's relatively heavy weight, so putting it in the back instead of front when driving on the roads/motorways shall improve the weight destribution and driving responce a little bit.
The following info could be of help for you in any case :
http://www.clubtouareg.com/forums/f66/another-winch-installation-in-progress-169537.html
http://www.touareg-club.net/forum/showthread.php?t=37359
Whats the name and size of the tires ?
Great looking build Dillion !! How has everything held up over the years ? I understand you went 25k on Alex's lift kit but have there been any issues after that with the cv joints or tires wear ( camber wear) etc , after that? I'm sure alot of us want to know the long term effects if there are any. Thanks!
Discussion starter · #115 ·
Tires have worn really well when keeping up on rotations. No complaints form the CV Joints. I have since had another lifted T2 and currently have a T3 Lifted with Alex's lift and they have all preformed exceptionally.
