1 - 20 of 42 Posts
I've taken my 2004 V6 Touareg in for a smog. They first told me to drive it a few hundred miles because I had just had a new starter put in. Now after driving 1200 miles it's still won't pass. The report states the OBDII is not ready. What does that even mean? It states the secondary air system not ready.
Anyone know what I have to do and how much it's going to set me back?
What? Why would they have you drive it after a starter replacement to pass smog?
Do you have a vagcom?
Sent from my SAMSUNG-SM-G920A using Tapatalk
I don't even know what that is, so I doubt I have it. I went to 2 different places and both places told me I needed to drive it.
I am so stressed, my tags are a month behind and no one seems to be able to help.
You don't know what smog is or you don't know what secondary air system is?
Dude go to a repair shop that specializes in VW or a dealership and get it diagnosed. Sounds like you don't know much about automotive repair and you don't have time to learn. Spend the money, get it fixed and learn about your car if your an enthusiast. This forum is helpful if you have a vagcom and know your way around an engine bay.
Dude go to a repair shop that specializes in VW or a dealership and get it diagnosed. Sounds like you don't know much about automotive repair and you don't have time to learn. Spend the money, get it fixed and learn about your car if your an enthusiast. This forum is helpful if you have a vagcom and know your way around an engine bay. Sent from my SAMSUNG-SM-G920A using Tapatalk
X2 a shop with vagcom can diagnose any issues or use vagcom to set the readiness.
He is referring to a special vw compatible cable to connect your car to a computer running vw diagnostic software,
There is a thread where people have posted if they have the cable and software, you just need to find a local thread member to you who can help you scan your car, it only takes 5 minutes.
http://www.clubtouareg.com/forums/f80/vag-com-locator-21142.html
It's not going to fix his issue, if the readiness code isn't setting with no c.e.l. there is an underlying issue that it probably at the professional technician level of comprehension.
You fail smog instantly if you have a c.e.l. on even if it passes the gas analyzer test
Discussion Starter #12
Thank you all. I have been to the mechanic that's done all of my work and he hooked it up to a machine and couldn't find anything wrong. I'm going to the dealer this weekend. I was just hoping to get a little knowledge so I didn't go in blind. The dealers out here are some of the shadiest and being female they see walking dollar signs.
Hi, when was the last time your vehicle had diagnostic check and tune up?
Some techs have found brand new vehicles barely meet emissions tests. Due to the age and possible high mileage your vehicle may have, it could cost you a lot to meet the emissions test.
When you take it to a shop for diagnostic testing, they will most likely say it needs a tune up to start. Air filter, spark plugs, etc. are usual wear items which require periodic replacement.
If no other faults are found, have it tested after the repair(s) are completed. If it still does not pass, you may be looking at replacement of catalytic converter(s), etc in the exhaust system of your vehicle.
If possible, get repair quotes from more than one shop.
Best of luck, this could get expensive to get your vehicle to meet the emissions test.
Mick
Most likely you were told to drive it because the monitors are not all set. Any time codes are cleared, it resets all the monitors. Once that happens, they have to go through their self test/set cycle. All monitors now have to be set in order to pass CA smog check. That includes the secondary air injection system. Secondary air injection issues will not always throw a CEL either. You definitely need to take it to someone who knows the vehicle.
And for those not familiar with CA smog, a sniffer is no longer used. Test is 100% taken through the OBDII port.
Discussion Starter #15
Yes
I've had a tune up, oil change, new starter, new gas pan, new fuel pumps and a few other pumps and tubes replaced. It passed last year without any work being done now after thousands of dollars in work it won't pass. ? I'm going to get it tested and will report back. Thank you all for your help or input.
Discussion Starter #17
Test results
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BF HW:
Component: MOTRONIC ME7.1.1G 6742
Coding: 0000133
Shop #: WSC 22539 444 54544
VCID: 50AF54DAC0A8E1BE8D-5122
No fault code found.
Readiness: 0000 0001
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 BD
Component: AL 600 6Q 0582
Coding: 0004153
Shop #: WSC 22539 444 85674
VCID: 71E9F15E6BE2C8B6A2-5140
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0014337
Shop #: WSC 31414 000 00000
VCID: 3A7B167276144BEE53-5140
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
VCID: 2D512D2EB75AEC56C6-5140
Component: ELV XXXX
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 3561054E5F0AA496BE-5140
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0100447
VCID: 4487688A04D00D1E39-5140
2 Faults Found:
00907 - Intervention load Management
000 - -
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00011915
Coding: 0012341
VCID: 2345CB16E19E2A2660-5140
Subsystem 1 - Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000031
VCID: 408F649A10C8113E1D-5140
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 970 L
Component: KOMBIINSTRUMENT RB8 1835
Coding: 0007231
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70EFF45A60E8C1BEAD-515E
1 Fault Found:
01304 - Radio
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
Shop #: WSC 00000 000 00000
VCID: 0407A88A4450CD1E79-515E
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F0D27662DB6AEC624-5140
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77FDCF46058696866C-515E
Part No: 7L0 959 933 E
Component: 2K HSG 0201
Coding: 0000085
VCID: 3E731A626A3C67CE6F-4AE8
Subsystem 1 - Part No: 7L0 959 701 A
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 A
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704
Component: Tuersteuergeraet HR 0201
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 65: Tire Pressure Labels: 7L6-907-273.lbl
Part No: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0211390
VCID: 75E1C54E1F8AE4967E-5140
2 Faults Found:
01507 - Initialization Not Successful
000 - - - Intermittent - MIL ON
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - Intermittent - MIL ON
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 377D0F4645065686AC-5140
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 F
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009289.02
End-------------------------(Elapsed Time: 08:33)--------------------------
Discussion Starter #18
The smog test is not stating I failed its stating that everything passed except for the air system and that says its not ready.
Like I mentioned above, the secondary air injection system will not always throw a CEL. As you now see...
The monitor is not set. That is the only thing keeping you from passing the smog check. Performing a VAGCOM scan will tell you nothing as there are no codes.
You really need to take the vehicle to someone who knows these vehicles. Its quite possible that this is a very simple fix. Just going to take someone that knows where to look.
Ditto, also you should have your charging system and battery checked for the load management dtc
1 - 20 of 42 Posts
