I have Thule cross bars on my 12 Touareg and they make a load whistle. Wondering if there are cross bars that don't cause so much noise (factory cross bars?).
Mucho grass in the pants.
Not wide enough? The whispbars are the widest crossbars out there. Also not sure why you think that they are not strong enough, I've used them on my B8 A4 for over 3 years with no issues at all and an A4 uses a flush rail system so they were held by the edges only. I've tried to use my entire strenght to pull them off without any success. On Touareg they are held by clamping over the rails which makes them that much more secure. If you know how to install them properly you should have no issues at all. I've driven over 100 with the roof top box with no issues.I've had the Whispbar but they are not wide enough or strong enough for all the crap I put up on the roof so I went back to using the standard Thule square bars and a wind fairing. Recently somehow the fairing cracked (maybe a rock strike, who knows) and thought I would try something different.
So all that is needed is to disrupt the airflow over the bars and the loud wind noise goes away. To do this, spiral wrap some cord (I used 1/8 inch I think) with about a 1 inch space between the spirals. I used some parachute cord I found at Lowe's, it was the only black cord they had. I'm pretty certain this is the best sounding solution I've had when comparing to the fairing or the Whispbars. It only cost a few bucks for the cord too.
I have the same setup on my '04 and I could not believe how quite it is. Only at HIGH speeds 80+ do I notice noise.rineman1 said:Try sliding them back and forth on the VW rails. Moving them a few inches may make a difference. I have a set of Thule Cross Bars and a Thule box on my '09 and they dont make a peep.
