1 - 6 of 6 Posts
driving along in my automobile.....
the car just stalled, dead on the highway...towed back here is scan
I'm looking for this g163, i found it on various sites but some say it is for touareg v8 some say no, some say for 07+ v6, some say no....i can't find any consistent information on this sensor.
Ebay says this is part number
07L-905-163C
ecstuning says this is part number
07L-905-163C
europa parts doesn't have T1 listed as compatible with that part number
FCP says it won't fit.
parts vw usa says it won't fit....
and VW lists 058905161B as the part..but a search turned out that it was the G40. so again I'm left with What is the G163?
So the question is what is the g163, do you have a picture you can point me to?
so the question is..... do you have the part number of a g163 that you've bought or that you know is right for the 4.2 v8
I also don't know where it is or i could just go rear it off of mine...
Saturday,31,December,2016,13:03:30:01401
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
Ross-Tech: Home
VIN: License Plate: 1231
Mileage: 277860km-172654mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: Mileage: 277860km-172654miles
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DA HW: 8E0 907 560
Component: 4.2L V8/5V G 0050
Coding: 0007875
Shop #: WSC 05001 444 82971
VCID: 68DFCE345876A20214-5140
9 Faults Found:
18104 - Powertrain Data Bus
P1696 - 002 - Implausible Message from Steering Column Controller - Intermittent
17944 - Camshaft Timing Adj. Bank2 (N208)
P1536 - 004 - Open Circuit - Intermittent
17887 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure - Intermittent
18627 - Oxygen (Lambda) Sensor B1 S1
P2195 - 008 - Signal too Low (Lean)
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - Intermittent
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - Intermittent
16434 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0050 - 004 - Malfunction / Open Circuit - Intermittent - MIL ON
16396 - Bank 1: Camshaft A (Intake)
P0012 - 001 - Advance Setpoint not Reached (Over-Retarded) - Intermittent
16730 - Camshaft Position Sensor (G163)
P0346 - 004 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 N
Component: AL 600 6Q 0578
Coding: 0004136
Shop #: WSC 05002 444 85870
VCID: 39795B70735CEB8ABB-5140
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 C
Component: ESP ALLRAD MK25 0107
Coding: 0014593
Shop #: WSC 31414 000 00000
VCID: 39795B70735CEB8ABB-515E
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
VCID: 2D517F20B714472A27-5140
Component: ELV XXXX
4 Faults Found:
01176 - Key
008 - Implausible Signal - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground
00087 - Terminal 30 for Starting Relevant Consumers
Part No: 7L6 907 040 T
Component: CLIMAtronic R/L 4222
Coding: 0001030
Shop #: WSC 08112 444 52478
VCID: 418933901B8CB34AF3-5140
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
(no units): 2.0
Temperature: 30.0°C
Temperature: 34.0°C
RPM: 0 /min
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0105693
VCID: 44873A84049EA662D8-5140
11 Faults Found:
00967 - Left Turn Signals
014 - Defective - Intermittent
01494 - Bulb for Parking Lamps; Left (M1)
010 - Open or Short to Plus - Intermittent
00978 - Lamp for Low Beam; Left (M29)
00968 - Right Turn Signals
01498 - Bulb for Parking Lamps; Right (M3)
00979 - Lamp for Low Beam; Right (M31)
00062 - Suspension Function Request
007 - Short to Ground - Intermittent
01517 - Control Module for Trailer/Towing Sensor (J345)
014 - Defective
00907 - Intervention load Management
000 - -
02088 - Lights for Auxiliary High Beams
01520 - Rain and Light Recognition Sensor (G397)
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00001399
Coding: 0012341
VCID: 23459918E1D0815A81-5140
Subsystem 1 - Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 5
Reset counter: 39
Time Indication: 0
Date: 2063.15.31
Time: 31:60:00
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2063.15.31
Time: 31:60:00
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000031
VCID: 408F36941086BA42FC-5140
2 Faults Found:
02031 - Switch for Steering Column Adjustment (E167)
014 - Defective
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 M
Component: KOMBIINSTRUMENT RB4 2935
Coding: 0007431
Shop #: WSC 05231 444 85892
VCID: 428B3C9C1E8AA852EA-515E
3 Faults Found:
00771 - Fuel Level Sensor (G)
00438 - Fuel Supply Sensor 2 (G169)
01304 - Radio
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70EFA65460A66AC24C-5140
1 Fault Found:
01304 - Radio
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1600
Shop #: WSC 00000 000 00000
VCID: 0407FA84441E666298-515E
1 Fault Found:
00926 - Terminal 30
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F0D75682DF805BAC5-5140
1 Fault Found:
02042 - Control Circuit for Motor in Transfer Case
006 - Short to Plus - Intermittent
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
VCID: 66C3C00C5262B47226-517C
1 Fault Found:
01344 - HID (Xenon) Headlight
012 - Electrical Fault in Circuit - MIL ON
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 B
Component: SG-Quersperre 5018
VCID: 377D5D484548FDFA4D-5140
2 Faults Found:
02412 - Differential Lock Rear
003 - Mechanical Failure
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L6 907 553 B
Component: LUFTFDR.-CDC- 3C1P1 3650
Coding: 0015520
VCID: 387F5E744856F28244-5140
2 Faults Found:
01598 - Drive Battery Voltage
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77FD9D4805C83DFA8D-515E
1 Fault Found:
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000003
VCID: 67DDCD085568AD7A1D-5140
1 Fault Found:
Part No: 7L0 959 933 E
Component: 2M HSG 0201
Coding: 0000085
Shop #: WSC 07200 444 54557
VCID: 3E73486C6A72CCB28E-4B00
Subsystem 1 - Part No: 7L0 959 701 A
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 A
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704
Component: Tuersteuergeraet HR 0201
10 Faults Found:
01134 - Alarm Horn (H12)
01504 - Bulb for License-Plate Light (X)
01331 - Door Control Module; Driver Side (J386)
00131 - Outside Door Handle Illumination/mirror Light Driver Side
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
00930 - Locking Module for Central Locking; Rear Left (F222)
01334 - Door Control Module; Rear Right (J389)
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 456
Component: 08K Audioverst. 0105
VCID: 70EFA65460A66AC24C-515E
Subsystem 1 - Part No: 7L6 035 456
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0080
Revision: 4A009002 Serial number: 00000134959183
Coding: 0016386
Shop #: WSC 00512 001 24584
VCID: 3F8D35686D78C5BA85-5140
3 Faults Found:
02579 - Trailer; Left Brake Lamps (M65)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 0
Time Indication: 0
02580 - Trailer; Right Brake Lamps (M66)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 0
Time Indication: 0
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 0
Time Indication: 0
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 F
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009289.02
VCID: 3A7B447C765AE092B2-515E
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
End-------------------------(Elapsed Time: 09:37)--------------------------
2008 V6
If you Google Search G163 you will get, G 163 (Oxycodone Extended-Release 40 mg) or Images for G163 Camshaft Position Sensor 2.
I think you want the images.
http://tiny.cc/olz5hy
Bob
thanks, thats where i started before i went shopping for the part. looks like i would have been right. thanks for the picture.
my mistake
when I replaced the seals during my 175k service, I carelessly didn't tighten the bolt behind the position sensor. This made that metal indexer flop around a little but cause no damage. i had already bought new sensors so i replaced them anyway. the only odd thing is the code said bank one, i made this mistake on the power steering fluid side not the Sai pump side. either way, the car started right up after tightening the bolt, now to replace the fuel pumps and i should be good to go for another 80k.
ended up being cam chain tensioner feet were destroyed.... i replaced the tensioners, chains and guides. car runs great so far.
1 - 6 of 6 Posts
