All four tyres must be identical - same make, same model, same size same tread depth with a 2mm variance permissible on the same axle and 3mm variance between front and rear axles.
Until you sort it all out, do not exceed 50 mph / 80 kph [same as the spacesaver spare] otherwise you will burn out the clutches in the gearbox.
