Hi All,
So I have a rather interesting problem that cropped up. I'll try and give as much detail as i can:
2012 Touareg TDI 3.0L 90k miles.
EDIT: I realize I left out a glaring issue i have, which is a P2201 NOX Sensor 1st Bank error code existing currently. Which I'm tempted to Delete....but That is also an issue.... Most likely unrelated to the issue below...
A couple days ago, I had a low coolant light come on, no big deal, the level was low enough to trigger it, so i (over)filled the tank and drove off. (Perhaps the issue could be TOO much coolant?!)
The following day, I went to drive and the car acted funny, maybe hesitated a bit, but I noticed quickly while driving that the temp gauge went up to just below the red overheating mark (maybe for a second or two), then came back down to the "actual" normal temp at 190*F. I pulled into a parking lot to look at it, nothing leaking or visually concerning, Having owned many crappy cars in my lifetime, I turned on the heater to hopefully dissipate some of the heat if it was in fact overheating. But there was no heat at all coming from the vents. So we drove home (5 miles) and parked it.
Today, I went out with a laser temp gun and let the car come up to temp and was constantly checking all the hoses. upper radiator hose heated up first, lower hose stayed cold for quite some time, but eventually, from what I could tell, the thermostat opened and the lower hose and the other half of the radiator heated up as well. (external hose temps of about 170*F, I would have to assume the coolant inside was at 190*F)
Still no heat from the heater. I opened up the fender liner to inspect the N82 Coolant Shut Off Valve and checked the temps and felt the hoses, all seemed cold, except what I could assume was the supply hose to the N82 itself, which was still only slightly warm from the residual heat of the main coolant, since it didn't seem to be flowing.
So Problem #1, I think the N82 might not be functioning?
Problem #2. While driving today, I filmed and noticed, fairly consistently, that after a mild/hard acceleration, when I let off the pedal, the water temp gauge would rise to just below overheating and return, within a second or two. and would rise accordingly to how hard I had accelerated. (hard acceleration, higher "temp", milder acceleration, mild rise in "temp")
I'll try and post the videos I records shortly.
Here you can see it right as I'm turning, and then as well, towards the end of the video is a great example of what it is doing. (Ignore the heavy mouthbreathing!)
I did check my battery voltage running (14.7V) and off (12.6V) I did use my OBD2 scanner and tested the battery as well and it indicated "warning", not sure what THAT means, but I haven't visually inspected the battery itself yet.,
Hopefully that explains my weird problems!
Thanks in advance!
I found this video, that seems to align with my problem possibly? As far as how the temp gauge is acting, his gauge was acting similarly. I'm not going to start with soldering the ECU though.... Start Free, Start Small....
Thanks in advance!
