Hello, new to this forum. Have a right Hand Drive Touareg. Squelchy carpet on Drivers side. Looked at this forum. Plenty of instances to learn from but none that ultimately diagnose my issue. I've cleaned the plenum drains, which I believe were never the issue. There's no sunroof on this model so no issue there. After much pouring of water on the car with nothing obvious showing up I went through the process of removing all the carped and most of the sound proofing from the driver's side footwell for a closer look.
Eventually I spotted a droplet of water coming out from a small hole in the front RHS Pillar. Applying a cloth to this drew a lot more water out. It seems that there is water pooling in a cavity in this pillar and eventually seeps out into the carpet. Bus I don't know how it's getting in.
My last step was to put some red dye in to this pool of water to 100% confirm that when it rains the water comes out of this hole, which it does.
See the pics here attached to show the location of the incoming water..
Wondering if this ca only com in from the top of the pillar and if anyone had ever experienced this. Suggestions and help would be much appreciated!
