1 - 7 of 7 Posts
If anyone knows where I can find one please let me know.
I saw a W12 at my local dealer, a movie was being filmed and VW supplied this W12 to the producers, it was imported from Saudi Arabia (the writing on the mirror was in Arabic). Be the time the movie was over the car was pretty much destroyed :(
Contact Rich at oempl.us You can get everything from him, here is the list of the part numbers just in case you want to get the things yourself since I see you are in Saudi Arabia and you can probably buy all the parts from your local dealer.
The W12 side skirts part numbers are:
7L9 853 751 GRU 1 <= left
7L9 853 752 GRU 1 <= right
For the front and rear valences and the heck spoilers the part numbers are:
W12 Front valence:
7L9 807 059(D) GRU 1 (D= for cars with park sensors) <= actual valence/spoiler
7L9 853 676 B41 1 <= center grill
7L9 998 163 GRU 1 (only for cars with park sensors) <= mounting set for park sensors
7L9 807 155 GRU 1 <= little cover for towing hook left
7L9 807 156 GRU 1 <= little cover for towing hook right
N 0385012 4 <= fixation clip/screw
7L9 853 663 GRU 1 <= housing for grill left
7L9 853 664 GRU 1 <= housing for grill right
7L9 853 683(A) B41 1 (A= for cars with fog lights) <= grill left
7H0 941 699C 1 (for cars with fog lights) <= fog light left
7H0 941 165 1 (for cars with fog lights) <= connector for fog light
N 90954201 3 (for cars with fog lights) <= screw
N 90419601 3 (for cars with fog lights) <= clamp
7L9 853 684(A) B41 1 (A= for cars with fog lights) <= grill right
7H0 941 700C 1 (for cars with fog lights) <= fog light right
7L6 945 071B 1 <= side reflector left (only used in US and some other contries)
7L6 945 072B 1 <= side reflector right (only used in US and some other contries)
W12 Rear valence:
7L9 807 434(D/G) GRU 1 (for cars without/with park sensors) <= actual valence/spoiler
N 90847501 4 <= fixation clip/screw
7L9 807 449 GRU 1 <= little cover for towing hook left
7L9 807 450 GRU 1 <= little cover for towing hook right
7L6 867 190 2 <= clamp for cover
7L9 807 675(B) 1 (B= for cars with park sensors) <= grill left
7L9 807 676(B) 1 (B= for cars with park sensors) <= grill right
7L9 807 087 GRU 1 (only for cars with external spare tire) <= mounting plate for license plate
7L9 807 847 GRU 1 <= center grill + lower plate
N 907 234 01 4 <= plastic screw to fix center grill + lower plate
N 906 633 01 4 <= rubber washer
7L6 867 190 4 <= clamp
7L6 945 105A 1 <= side reflector left
7L6 945 106A 1 <= side reflector right
W12 Heck spoiler:
7L9 827 933A GRU 1
Facelifted '08 Treg Heck spoiler:
7L6 827 991B GRU 1
W12 Sport flairs:
Front left
7L9 853 717 GRU 1
7L9 853 727 GRU 1
Front right
7L9 853 718 GRU 1
7L9 853 728 GRU 1
Rear left
7L9 853 873 GRU 1
7L9 853 817 GRU 1
7L9 853 827 GRU 1
Rear right
7L9 853 874 GRU 1
7L9 853 818 GRU 1
7L9 853 828 GRU 1
W12 'double pipe' exhaust:
Left:
7L9 253 681 B 1
Right:
7L9 253 682 B 1
NOTE! The last digit at the end of each part code is actually the QTY required (mostly just 1)
Re:
Actually the W12 in the touareg is a gasoline engine. It has slightly more horse power than the TDI in the Q7 but the torque of the TDI is almost double.
Thanks for the great info Neverfollow.
Basically the same as the R50 body kit. With the exception of the wheels, roof bar and twin exhaust pipes.
Must admit, I'd like the twin pipes for my R50, sweet.
1 - 7 of 7 Posts
