Hello,
I have a problem with the air suspension. So every morning when i go to my car the front of the car is almost completly down and the back is perfectly fine. And it doesent do it overnight, at first when i turn of the motor and pull out the key the front susp. goes down about half way, like your lowering the susp. from the button, and then the other half goes overnight like its leaking somewhere.
Oh and when i drive on a perfectly fine road with no bumps or holes, every time i get the Running gear fault message.
I did a check with VCDS and i found this code:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal
