341 - 360 of 568 Posts
Many thanks to Lysy and and DrGER (and everyone else) for sharing your time and knowledge with us. I joined this forum years ago and haven't checked in for a while. A DDG search on RNS850 mapping updates and here I am. These map changes will be of great use living in Central FL with never ending road construction.
I had a 2012 TREG and now a 2016TREG. Best vehicles I have ever owned (I'm old and have owned my share).
I will be attempting the mapping update soon. I'm retied from IT/Data Networking Engineer and .sh and other terms bring back fond memories (20 years retired) of Berkley BSD 4.2. Wow, things have changed.
My current version is P0737. Mapping was updated by the dealer a few years back and I'm at V10 NAR 6.14.2
Thanks again! Hope the update goes smoothly.
You RNS850 software is up-to-date with P0737. NAR 6.14.2 was released back in 2014 by NavTeq for Harman-Becker. The NAR update offered by Lysy here (adapted from the Audi media) was released in mid-2020; still, better than no update. The (very) last MMI3G update was released in 2022; we stil haven't seen anyone sharing the NAR media anywhere.
BTW, the real-time QNX system used in your RNS850 main unit was "current" 20 or so years ago, at the start of the Harman-Becker MMI3G project for the Audi A8. The shell command environment is not complete for the 32-bit RISC processor used in MMI3G system, but we have enough of it to be useful. Good luck with your navdb update. --g
Unfortunately, the update did not go well. I'm unsure of the cause and I performed it twice with the same result both times.
I had no issue decompressing files (RAR and ZIP for activation).
Started the update after toggling all fields to Y
I checked the progress a couple of times and everything seemed to be downloading
I got to the following screen:
I selected to continue from the screen above and this is what came up:
I selected cancel documentation and the system rebooted and the what came up appeared to be the updated NAV screen. All appeared ok so I removed the FOB, disconnected the charger and started the engine.
The following screen came up. I put the activation script SD in and the script said it was executed but I still have the activation request.
As I mentioned above, the vehicle was updated to V10 by the dealer and I have a sleeve with an activation code. I have no idea if that's what needed to how to try it.
Any help would be greatly appreciated.
Thanks in advance.
@fishon -- A couple of points: first, in the first image above, you should scroll through the list of RNS850 components and look for the update status in the right column; the image you posted shows only installed components that are not part of the navdb update (indicated by the '-' character). We want to see if any of the updated navdb components are not "OK".
Second: You need to restart the RNS850 system for the navdb unblocker patch to take effect. --g
@DrGER, I appreciate the response. I am uncertain of how to fully restart the RNS850. I left the vehicle sitting for three hours. I just started it and the NAV worked for a few minutes before asking for activation. I inserted the script SD and as above it recognized it and ran the script but is still asking for activation. I can only guess the SD card w/script must be in the reader when the RNS850 is restarted after a few hours. Is there some way to manually force a restart or do I let it sit overnight w/SD script inserted and hope it reads it in the morning?
Thank you for your assistance, the map looks great for the short duration I can view them.
@fishon -- Restart the RNS850 manually by pressing [PHONE]+(O)+[NAV] at the same time, where (O) is the center scroll knob.
Regarding the navdb unblocker script, make sure the SD card is not write protected and review the plain-text log file saved on the SD card for error messages after ejecting the SD card. All of this should "just work" (when the navdb update completes without error). --g
Thanks for the reply's. I will try it this morning. I did not do the reset using the 3 buttons. I had assumed when the system restarted after the update it was a "restart". I will try it using the 3 buttons with the script inserted. Card is not write protected. The script was acknowledged and I pushed the center button to execute and it appeared to accept w/o error.
Thanks again
Ok, figured it out (or you guys did). II was using the .zip activation file that @DrGER had linked on page 7 of this thread. I think that was a sample file for activation. The log files revealed some errors that gave me a clue.
I went back and downloaded the file from Mega that @Lysy had linked in the original thread. It appears to have executed properly and I'm not getting the message for activation (at least not after driving 5 minutes).
Many thanks to @Lysy and @DrGER! I can't thank you enough for all the help!!!
The SD script you found on page 7 of this thread removes the production navigation datatbase FSC activation file from the system and saves it to the SD card. This is needed to clear a fault code in Address 5F when the MMI3GApplication process finds no valid activation files in persistent flash memory. It has nothing to do with "activating" or otherwise enabling access to the updated navdb. What you were looking for is posted in my GitHub repository: GitHub - DrGER2/MMI3G-Navdb-Unblocker: Patch MMI3G/3GP systems to unblock access to an updated navigation database.
Unless you buy the proper VW navdb "activation document" from a dealer and then pay (again) to have the ODIS SVM activation process run on the car to create a new FSC file for the VIN/navdb release, your updated navdb is not activated. My "unblocker" patch script (and all the so-called "activator" scripts since early 2016) essentially disable the normal navdb activation process used by Harman-Becker in their MMI3G systems since the about 2008 or so. The exploit was discovered by Keldo in 2015 and a fellow named Vlasoff posted the script masquerading as an "activator" in early 2016. Disabling the internal activation process has a few side-effects, but none that prevent future navdb updates or affect the operation of the NAV/MAP function. --g
All seems to be working great after running the script posted by @Lysy early in this thread. I was having trouble with Mega at first and downloaded the update from the link to google drive. I then saw your zip file and thought it was another script to address the activation error. Instead, I guess I removed the FSC activation file by running it. I do have the original dealer activation code on a sleeve but no media. The updated maps are amazing compared to what I had before (I think you mentioned V10 was 2014).
Thanks again for all the help.
... I do have the original dealer activation code on a sleeve but no media. ...
That would be the nav database "activation document". The dealer service department uses that information as input to the ODIS SVM - Activation process, which creates an encrypted FSC file stored in persistent flash memory of the MMI operating system for the specific VIN & navdb release. My SD script removes only the FSC file that causes the specific fault code; the MMI system keeps a backup of production and ODIS generated FSC files in another part of persistent flash memory. The important point is that you can access the NAV/MAP functions correctly, so no further action is needed. And if someone does share the last NAR navdb update, you won't need to run the patch script again (since the navdb isn't really activited now, anyway). --g
That makes sense. I did a little reading yesterday to better understand this (MMI, ODIS SVM).
Thanks again.
Can you please specify what those side-effects are?
First side-effect are DTCs at Address 5F due to missing and invalid FSCs found in /mnt/efs-persist/FSC persistent flash memory. We know that these are harmless, and can be cleared using appropriate procedures.
Second side-effect is subsequent navigation database updates cannot be run as "Standard"; "User defined" is required to select all components of the new navigation database release manually. Not a serious matter, but requires either access to the Green Engineering Menu (to enable user-defined software updates) or a modified metainfo2.txt file in the release media that allows selection of "user-defined" update.
Last side-effect that I can think of is the risk of /mnt/efs-persist/navi/db/acios_db.ini (the navigation database initialisation file) not being created after an update. When this happens, the acios_db.ini file must be added to the system by alternate means (either from a known working acios_db.ini for that navdb release or with a script that references the navdb release PKG file).
For EU MMI3GP/RNS850 users, this really isn't a problem anymore, since you-all have the final update released by Harman-Becker/Audi for this system architecture (6.36.0). Other regions (NAR, ROW, ROW2) that haven't seen the final navdb release can still experience these side-effects. --g
From what I've read, and I could be wrong, there has not been a definitive/solvent procedure for fault # 03175- Invalid Data Set from updating the RNS850 firmware without being hooked up to the VW Mothership.
Maybe you're thinking of DTC 03276 - Please Check Software Version Management. This is cleared using the checksum value in Adaptation Channel 15. DTC 03175 is rare; some suggest that it can be cleared in the /dtc Green Engineering Menu. I have not encountered it. --g
No I got the 03276 to clear a while ago by another members suggestion in a thread. I had 2 faults in the 5F module after updating the firmware myself. See VCDS scan I did 5/22/24.
Ignore the faults for 01-Engine. Had coolant pump "B" STB and the connector going to it. I'm working on it. :cool:
Code:
Wednesday,22,May,2024,01:24:45:40064
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 23.11.0.0  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVGFF9BP4BD001067   License Plate:
Mileage: 185690km-115382mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGFF9BP4BD001067   Mileage: 185690km-115382miles
08-Auto HVAC -- Status: OK 0000
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 B    HW: 03H 907 309
   Component: 3,6 FSI ULEV2 H11 8643
   Revision: M7H11---    CVN: A886D4C9
   Coding: 002A0012433600000000
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_ECM36FSI01103H906023B 002005
   ROD: EV_ECM36FSI01103H906023B.rod
   VCID: 211FE5B75140220200D-8074
   VINID: 9E65D65894A01125000010061CB0E99A52
2 Faults Found:
12348 - Coolant Pump 2
          P261A 00 [01100100] - Open circuit
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 185646 km
                    Date: 2024.05.21
                    Time: 13:12:12
                    Engine RPM: 2040.00 /min
                    Normed load value: 13.7 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 81 °C
                    Intake air temperature: 33 °C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 14.630 V
                    Unlearning counter according OBD: 40
                    Relative load value: 12.70 %
12351 - Coolant Pump 2
          P261C 00 [11101101] - Short to GND
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 185654 km
                    Date: 2024.05.21
                    Time: 13:18:58
                    Engine RPM: 1866.00 /min
                    Normed load value: 47.8 %
                    Vehicle speed: 12 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 34 °C
                    Ambient air pressure: 980 mbar
                    Voltage terminal 30: 14.465 V
                    Relative load value: 42.89 %
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 A    HW: 0C8 927 750 A
   Component: AL1000 AISIN  001 1824
   Serial number:                CVN: DB98ADE3
   Coding: 001368
   Shop #: WSC 12138 004 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 2A0D029B2C76E15A517-807E
No fault code found.
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 G    HW: 7P0 907 379 A
   Component: MK25A         H33 0421
   Revision: --------    Serial number: 417400010EC010 Dataset Number: 7P0012v____ 7P08
   Coding: 5B7613C349242554DAF4C89992D9A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 41DF4537B100020260D-8014
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 H
   Component: BCM2 2.0      H13 0208
   Revision: 00002001
   Coding: 09860000000000000000
   VCID: 72BDDAFBC4A6E99A297-8026
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0510000041856011
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 0210000092414004
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 AA    HW: 7P6 907 040 AA
   Component: Klima 2 Zonen H18 0612
   Coding: 4606200A80
   VCID: 73B3DFFFBB3CE092221-8026
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H11 0083
   Revision: 15011002    Serial number: 00000000581650
   Coding: 26081013943C6D010001180700005D0CC31C660882010261000000020000
   Shop #: WSC 12345 123 61029
   VCID: 290FFD9729F0EA4258D-807C
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    100705  31  0020
   Serial number: 90243400100708103232
   Coding: 0045BD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10037851
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000107100091
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R026W06
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 A    HW: 7P0 959 655 A
   Component: VW10Airbag099 H05 0020
   Revision: --------    Serial number: 003FH000LVMN Dataset Number: 7P6003v____ 0711
   Coding: 000000000000000000000000000000003939
   ASAM Dataset: EV_AirbaVW10BPAVW526 001001
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 3FDB43CFC7F474F2169-806A
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R10317004NF
   Serial number: 3575LRB405L6U4L25PA/
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3585LRB405J6U4L2E8N1
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 3515RRB40536T8MIB8H
   Passenger side rear thorax airbag crash sensor:
   Serial number: 3525RRB40536T8MIC0HW
   Serial number: 3555NRB405B6OBGCE95O
   Serial number: 3565NRB405B6OBGC9H8V
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4H0 953 568 A    HW: 7P6 953 507
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JG20001J
   Coding: 000015
   VCID: 313F15F70120928290D-8064
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0017759
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 980 M    HW: 7P6 920 980 M
   Component: Kombi         H09 0231
   Revision: 08140052    Serial number: 658100710593018
   Coding: 837632022B00D705020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 46D5562B982E253A55F-8012
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000023910
   Coding: 0001032600
   Shop #: WSC 131071 1023 2097151
   GVL: FB0F40451D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 382928D3E2DA43CAD73-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650276717
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000006118150
   Coding: 0058130000004001000001010101202020202121202020
   Shop #: WSC 25038 444 92088
   VCID: 34311CE3FE32A7AAFBB-8060
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000105976241
   Coding: 011D07205E00453005080000
   Shop #: WSC 00017 666 02354
   VCID: 3C2134C3D6626FEA33B-8068
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0131550612
   Coding: 0106163A28B9509482B00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 090101718
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H05 0006
   Serial number:     WOO10189441
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H06 0006
   Serial number:     WOO10197833
   Coding: 191100
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000106166111
   VCID: 3B2337DFD36C68D23A1-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
   Component: EPB           H51 1100
   Revision: 00000000    Serial number: A10618000AB    Dataset Number:             A001
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 353721E7F5C8BEA2CC5-8060
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 5P0036v____ 0005
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1F4C39662AFEA73B-8028
   Left_headlamp_power_output_stage:
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0006
   Coding: 130000
   Right_headlamp_power_output_stage:
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0006
   Coding: 130000
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G0 035 082 G    HW: 4G0 035 082
   Component: Radio U SIRIU H51 0133
   Revision: AB001007    Serial number: 471G+0A7513777
   Coding: 020007020000000001
   VCID: 2411ECA34ED2372A6BB-8070
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H43 0706
   Revision: --------    Serial number: 445G$0A7504549
   Coding: 010200050040E1EE01022B0C00000003F00801010000000000
   VCID: 392F2DD7D9505AC228D-806C
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H23 0045
   Serial number: VWZ8Z9K29000BU
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Subsystem 4 - Part No: 8R0 060 961
   Component: CD-Database  1886
1 Fault Found:
03175 - Invalid Data Set
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 185645 km
                    Time Indication: 0
                    Date: 2024.05.21
                    Time: 13:09:45
             Freeze Frame:
                    Voltage: 14.50 V
Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000106117180
   Coding: 011C07200000253005080000
   VCID: 3A2D32DBDC5651DA217-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000005901 Dataset Number: 7P6096v____ 0014
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 B    HW: 7P0 907 383 B
   Component: Anhaenger     H07 0100
   Revision: 5A001002    Serial number: 00000131775465
   Coding: 020D000000000000
   VCID: 372B2BEFEF444CB2DE9-8062
Address 6C: Back-up Cam.        Labels: 4L0-910-441.clb
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H03000    Serial number: 525PA8-J050845
   Coding: 0110001
   VCID: 372B2BEFE3444CB2DE9-8062
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 09145444    Serial number: 168000257 Dataset Number: 7p0771v____ 0009
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000106116354
End----------(Elapsed Time: 02:18, VBatt start/end: 12.5V/12.5V)-----------
Discussion starter · #360 ·
Invalid data set refers to a function that You've probably enabled in the Green Menu, but is not enabled or present from the factory. Maybe AUX output or any other option in the 5F module.
