201 - 220 of 510 Posts
I've seen them and i like. I read somewhere here? that i can upload only the MapStyles?
The Map Styles archive used by the MMI3GApplication process is defined in the navdb PKG file (based on the installed region code). At run-time, MMI3GApplication creates a (new) symbolic link from /HBpersistence/navi/db/MMI3G_MapArchive.xar (in flash filesystem /mnt/efs-persist) to the archive stored in the HDD /nav partition, based on the region code. For an ECE release (region=1), this link is to /database/map/styles/01/MMI3G_MapArchive_H_06_01.xar (/database is symlinked to /mnt/nav) -- on an RNS-850 variant, the equivalent Map Archive file is /database/map/styles/01/VW526_MapArchive_H_06_01.xar.
An experiment I have not done yet is to replace the HDD MapArchive file with a different region or style, but it's easy to do with an SD script. For the ECE region 01 map archives, we see that the Audi & VW versions are not the same (file size in bytes listed):
Code:
5723632  MMI3G_MapArchive_H_06_01.xar
6630744  VW526_MapArchive_H_06_01.xar
Now, why would that be ? Unfortunately, I haven't determined how data is stored in this archive file, so direct inspection hasn't happened yet. --g
Just intalled Lysy's maps on K0821, the script wasnt needed. I didnt had time to play more but so far i really like it. During the instalation i had the same problem (see photo) on almost all modules and i had to press Retry, Retry, Retry..Retry. Whats up with that and how this glitch can be fixed? Even if i dont use the Navi (maybe to check speed limits when im abroad and being more of a Google Maps fan), overall i'm very satisfied.
Good job, Lysy! 🍻
edit:
Some glitch found.
There is no automatic day/night switch. On my previous build i had automatic day/night and when the driving lights were turned on the Navi switched to night mode.
Discussion starter · #206 ·
If You choose one option from the screen You posted, the automatic function will be disabled. System will stay on the mode You've selected. You need to go to the setup section and pick automatic mode. It definitely works and has nothing to do with the maps.
Here's the newest 2023 available map update for the RNS850 Europe Region:
1. You can't find this archive anywhere in the internet, cause it's made by myself. It's a simple Audi MMI3GP conversion.
2. Databases are 100% identical with VW standard. There is no ingeration in originality of the databases.
3. This package is CHECKED, I've installed it to my RNS850 and it runs flawlessly.
4. Don't use Green Menu, You need to use User Defined method selecting Y for all available options (except for Bootloaders) .
5. Special destinations search section (POI) will be empty, Special destinations online do work. They require internet connection of course, and to have them Google Earth must be enabled. If many people will be interested, I can make maps with old 6.32.1 offline POIs.
6. Don't ask how to upload it into Your RNS. There's answer for that in the internet.
7. If Your map won't work after 3-4 minutes after the update don't panic. It means You need to activate it. This scripts slays process which checks if the maps are activated. Here, it will make Your maps work:
or unblocker from DrGER:
8. Please RESHARE. If You've downloaded it, upload it to any possible server to share with other people. Even You can post alternative links in here. I've seen many offers for upgrading this version for money, please don't do this.
9. All the functions like TMC and others work.
10. If someone is successful with updating, please don't be shy and let us know.
11. This map works with P0824 firmware. I have no experience for version below them.
12. If You don't know what to do please ask for help. No shame in it, but don't be lazy.
13. Don't use MacOS to extract or upload Your files onto SD Card!
14. When You'll have 03623 or 03276 errors in 5F module after the update I can help fix them (one of them requires VCDS).
This is how to solve one error:
This is how to solve the other:
15. Use solid SD Card, not a microSD with adapter.
16. Here's P0824 firmware (for ROW - Rest of World and ECE - Europe only):
P.S. Feel free to ask me any questions (except for stupid ones).
New look:
Installation successful:
[/CITATION]
Bonjour tout le monde
When decompressing the "v13.rar" file, the software asks me for a password, what is it?
@laurent -- You want the FIRST link from the FIRST post of this thread -- the file name is "RNS850 8R0060884KL.rar" it is NOT password protected. But first, you should confirm that your RNS850 has software version HN+_EU_VW_P0821 or later. If not, you should update to HN+_EU_VW_K0821 (MU version: 0934) first. --g
Hello DrGer
I already have HN+ EU VW P0824.
On the other hand, when I decompress the files either with 7zip or BreeZip, a password is requested.
@laurent -- I do not know anything about the V13.rar file you downloaded. The navdb update made by @Lysy for RNS850 systems using the Audi ECE 6.36.0 update media referenced in the first post of this thread is NOT password protected. --g
